edelbrock carb puking fuel after sitting? #175018
12/25/08 07:33 PM
12/25/08 07:33 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Thanks everyone. It ended up being both the float and needle. Everything is taken care of and its running great and receiving a oil change currently..
I'm trying to help my neighbor get his old 55 going. It has a small block with a edelbrock 1406 600 cfm carb. I can get the car to run and keep going as long as I hit the gas, but it won't idle or run at a steady rpm. I'm guessing there is a float issue or something like that but I'm only really familiar with the holley's so I'm not to sure where to start. The car has been sitting for 2 years but has fresh gas. It also seems to be puking some gas from the top of the carb.
Any idears?
Thanks!
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: edelbrock carb puking fuel after sitting? [Re: blown340] #175019
12/25/08 07:43 PM
12/25/08 07:43 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: edelbrock carb puking fuel after sitting? [Re: Neil] #175020
12/25/08 07:49 PM
12/25/08 07:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Stuck needle and seat due to old fuel sitting in bowls.
How much fuel burped over and how long did you try to run it that way. Any amount of gas going in like that should have the oil and filter changed to get excessive gas out of the oil.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: edelbrock carb puking fuel after sitting? [Re: MoparforLife] #175021
12/26/08 01:49 AM
12/26/08 01:49 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
If it's not a stuck float valve, check the accelerator pump diaphram for tears/leaks.
Re: edelbrock carb puking fuel after sitting? [Re: Lefty] #175022
12/26/08 01:57 AM
12/26/08 01:57 AM
I'd pull the top off of the carb & see what you see.
Re: edelbrock carb puking fuel after sitting? [Re: blown340] #175023
12/26/08 02:07 AM
12/26/08 02:07 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Sounds like a classic case of stuck float or needle valve.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
