Methods for stripping an engine bay down #1749388
02/08/15 08:07 PM
02/08/15 08:07 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'd like to get my engine bay down to bare metal while things are apart and am trying to find the most effective way, on a budget, to do it. Sending the car out for work isn't a viable option right now.
Options I see are:
Chemical Stripping - Seems like a mess!!!
Angle grinder with a cup brush - It'll work, but slow process
Portable/Small Media blaster - I have a 60gal compressor, seems like an option?
Which have you done and what would you recommend?
Thanks-
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Methods for stripping an engine bay down [Re: GoodysGotaCuda] #1749389
02/08/15 08:24 PM
02/08/15 08:24 PM
Go buy a quart of aircraft stripper and follow the directions to the letter That or a batch of the cheap fiber type strippers for your drill or buffer from Harbor Freight or some other cheap tool source like them
Re: Methods for stripping an engine bay down [Re: Cab_Burge] #1749390
02/08/15 08:33 PM
02/08/15 08:33 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
The first time I did one I just used scrapers, is is a mess but so is blasting and it can actually by a BIGGER mess, DAMHIK!
JB Rhinehart, Realist
A-Body's RULE!
Re: Methods for stripping an engine bay down [Re: Rhinodart] #1749391
02/08/15 08:49 PM
02/08/15 08:49 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Chem stripping is am amazing mess and a big chore especially in an engine bay...but its the best at getting to everything...I used a metal etch primer before paint and 8 years later that car still looks mint..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Methods for stripping an engine bay down [Re: 72N96RR] #1749392
02/08/15 09:10 PM
02/08/15 09:10 PM
jersey
Spaceman Spiff Offline
jersey
What about a mobile soda blasting service?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Methods for stripping an engine bay down [Re: Spaceman Spiff] #1749393
02/08/15 09:34 PM
02/08/15 09:34 PM
IN
ahy Offline
ahy  Offline
IN
I used aircraft stripper and a pressure washer. Lay it on heavy, let it work and blast it off. This done before exterior paint work... not recommended if the exterior is already painted as any stripper that "splashes" on good paint may damage it. A couple rounds got most of the paint off. Final touch was a stainless scrub pad + stripper to get the last of the factory primer off. Follow with lacquer thinner, sand and prime.
If the exterior is already painted, I'd probably use the cup wire wheel + sandpaper then prime and paint.
It will be time somewhat consuming and dirty either way you do it.
Re: Methods for stripping an engine bay down [Re: ahy] #1749394
02/08/15 10:55 PM
02/08/15 10:55 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've always used the wire brush-scrape and sand method.
I bought an electric DA thru Dewalt and it makes it so much easier.
No waiting on air and no noisy compressor running nonstop.
Do yourself a favor and be sure to use some seam sealer around all of the areas where the panels are joined together. Use a very small amount and pull it tight like installing caulking. I've seen a few that were wire brushed, primed and painted and then started to show faint rust lines around the edges of the panels. Sucks when that happens since there is no good easy fix...
...FAFO...
Re: Methods for stripping an engine bay down [Re: skicker] #1749395
02/08/15 11:09 PM
02/08/15 11:09 PM
NY NY
3
340duster340 Offline
NY NY
if you use a scraper, make sure to use something that is non-marring and not-reactive with the chemical.
like a bozo, i took a metal scraper to my inner fender to remove undercoat (after soaked in chem), the coat came off, but i also scratched the crap out of the metal.
Re: Methods for stripping an engine bay down [Re: 340duster340] #1749396
02/08/15 11:24 PM
02/08/15 11:24 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I normally blast engine bays for around $100-150. you say budget so that may be too much. watch Craigslist for a used pot and find some fine media (50-100 grit) and just go to work. it will be slow and painful but you will come out with a nice finish. if your compressor is under 5cfm it will be super slow.
Re: Methods for stripping an engine bay down [Re: GoodysGotaCuda] #1749397
02/08/15 11:28 PM
02/08/15 11:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Options I see are:
Thanks-
I would never recommend any kind of abrasive media unless the car was a absolute bare shell. Because the media get's everywhere and nothing can be exposed to it while blasting. Plastic and tape is not enough.
Car inside or out?
Gasoline is cheap and cuts grease and grime fast and well.
Put it in a pump up garden sprayer and a parts cleaning brush from the auto parts store works really well and won't damage the metal. Gets in all the nooks and crannys better than any thing else by hand.
Then if your got room to media blast, then I'd say pressure washer after that. Pressure washer is your friend and is perfectly suited for this kind of job.
Otherwise a wire brush on drill, but is so medieval to me. Like said, A putty knife and a torch would be my last choice and will scrap up the panels.
Re: Methods for stripping an engine bay down [Re: chrisf] #1749398
02/09/15 12:04 AM
02/09/15 12:04 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thank you for all of the replies!
To touch on chemical stripping, the rest of the car is painted. I'd like to keep that paint, at least for now. Splash would definitely be a problem.
The car can be inside or out without much trouble, it's on casters and I have a flat driveway.
The engine bay isn't dirty, but with welding up a bunch of holes and grinding the welds, it seems as if I'd be better off stripping everything and laying down fresh primer.
Seems like wire-wheelin' is still my best bet. I think the one I was using was a little too soft bristled/worn out to be very effective. I'll grab a new one, or three and get after it this weekend.
2020 RAM 1500
Re: Methods for stripping an engine bay down [Re: GoodysGotaCuda] #1749399
02/09/15 01:06 AM
02/09/15 01:06 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I don't have luck wire wheeling paint off, it kind of heats the paint up rather than removing it. I think with good paint on the rest of the car I would sand it all off, it's dusty but it won't damage the exterior paint in any way. DA most of it and hand sand where the DA won't go. Before doing anything though liberally wipe it down a couple of times with wax and grease remover, don't be frugal with it.
That's how I did this one. I had the car painted and then drove it 500 miles home, tore out the engine, rebuilt it and painted the engine compartment.
Sheldon
Re: Methods for stripping an engine bay down [Re: RUNCHARGER] #1749400
02/09/15 01:19 AM
02/09/15 01:19 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Big open areas = These in a drill http://img4-3.realsimple.timeinc.net/images/daily-finds/home/0509/df-3M-paint-rust-2_300.jpg
Way better than any wire wheel for paint removal + they leave a great finish to apply primer to. Wear a dust mask or you'll have black boogers for a week.
Tight spots = chase down by hand using 80 grit wrapped around a popsicle handle, wood paint stir sticks ect. NO metal as a backer as it can gouge the sheet metal if it pokes thru the sandpaper
Seams = dental pick(s).
You can get the paint off with surgical precision using the above. Don't drag the drill extension chord over your fenders.
Re: Methods for stripping an engine bay down [Re: GoodysGotaCuda] #1749401
02/09/15 01:28 AM
02/09/15 01:28 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That is what I would use. Soda if possible. Just avoid areas where it could go in the car. Media will get all the nooks and crannies. The rest you will need to manually remove with various media/grit wheels or discs.
Re: Methods for stripping an engine bay down [Re: Cab_Burge] #1749402
02/09/15 02:37 AM
02/09/15 02:37 AM
Wisconsin
stew Offline
stew  Offline
Wisconsin
I needed to do an engine bay in a Mustang in exchange for wedding photos. I used Easy Off oven cleaner and a pressure washer. The oven cleaner removed the Ziebart rustproofing that had been there since '67, took off all of the paint and primer to the bare metal!! It did not harm any plastic or rubber parts, just make sure you cover places you don't want it to go, like down the cowl vent. Did this one while the engine was in the car, and it cleaned up everything! Spray the oven cleaner on and let it sit for 5 minutes or so. DO NOT let it dry on. BE SURE TO WEAR EYE PROTECTION ( GOGGLES !!) AND A FACE SHIELD !! COVER ALL EXPOSED SKIN!! THIS STUFF IS MEAN AND EFFECTIVE !!
Worked for me. JUST BE EXTREMELY CAREFUL.
You'd have to be NUTS to use gasoline!! One small spark to set off the vapors and you're toast!
Re: Methods for stripping an engine bay down [Re: stew] #1749403
02/09/15 02:53 AM
02/09/15 02:53 AM
GA
roadrunninMark Offline
GA
I used a "paint removing" wheel that you put in a hand held drill. 3M makes them and they are in Walmart, should be in the auto section where the paint and bodywork is. It does a pretty good job and is a lot cleaner then chemical strippers. Just dont stay on one spot too long as it will heat up the metal and could cause it to warp. I did the outside of the barracuda down to metal. It will take out puddy too.
Re: Methods for stripping an engine bay down [Re: roadrunninMark] #1749404
02/09/15 06:34 PM
02/09/15 06:34 PM
GA
GA
I found a pic. Way faster then a cup with wire brush and does a better job. It doesnt throw pieces of wire either. Use the "end" not the flat to do the stripping.
Re: Methods for stripping an engine bay down [Re: roadrunninMark] #1749405
02/09/15 08:06 PM
02/09/15 08:06 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I use these all the time and they work great.
Re: Methods for stripping an engine bay down [Re: 5carguy] #1749406
02/09/15 10:30 PM
02/09/15 10:30 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Do it right
Remove all the hardware out of the engine compartment.
Steam clean if possible or pressure wash. Use a putty knive for those thick greasey areas
Wash with hot soapy water and rinse.
Once dry wipe down with grease and wax remover.
Weld all unnecessary holes, DA sand, fill were necessary and prep for paint
Re: Methods for stripping an engine bay down [Re: dart4forte] #1749407
02/09/15 10:36 PM
02/09/15 10:36 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
No need to completely strip to bare metal - a lot of work for nothing. Clean it well. Weld, grind, prime, fill, sand, scuff the whole thing, prime the whole area and paint.
