HEI DIST. #1748945
02/08/15 01:49 AM
02/08/15 01:49 AM
ohio
Sherminator Offline OP
ohio
What all is needed to hook one up in a 81 one ton
Re: HEI DIST. [Re: Sherminator] #1748946
02/08/15 09:59 AM
02/08/15 09:59 AM
pennsylvania
poboyengineering Offline
pennsylvania
I don't know which one you have, but the stock GM stuff only requires a 12 source that is hot in both start and run.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: HEI DIST. [Re: Sherminator] #1748947
02/08/15 01:32 PM
02/08/15 01:32 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I just use the hei module on a dodge distributor.
Re: HEI DIST. [Re: cageman] #1748948
02/08/15 08:45 PM
02/08/15 08:45 PM
ohio
ohio
looking at them on e bay
Re: HEI DIST. [Re: Sherminator] #1748949
02/10/15 10:39 AM
02/10/15 10:39 AM
ohio
ohio
Bump
Re: HEI DIST. [Re: Sherminator] #1748950
02/10/15 12:26 PM
02/10/15 12:26 PM
Az
Crizila Offline
Crizila  Offline
Az
If you go with a one wire D.U.I. - - one wire.
Fastest 300
