Re: 833 Electronic Speeometer sending unit
[Re: AlexP]
#1747558
02/05/15 11:50 PM
02/05/15 11:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looks like it screws in place of the speedometer cable.
[Re: OzHemi]
#1747560
02/06/15 04:00 PM
02/06/15 04:00 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My 92 D250 has both mechanical and electric output for the speedo/odo. Perhaps that could be of some use.
[Re: feets]
#1747561
02/06/15 04:39 PM
02/06/15 04:39 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The pulse rate of the sender has to match the speedo being used.
[Re: John_Kunkel]
#1747562
02/06/15 05:01 PM
02/06/15 05:01 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Maybe use a Dakota SGI-5 C Speedometer calibrator?
I thought I needed one but ended up using GPS speed instead
[Re: John_Kunkel]
#1747563
02/06/15 11:32 PM
02/06/15 11:32 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
The one in my buddy's car (VDO) can use different pulse count sending units it says. You then calibrate it by a set mile and go from there...
[Re: cageman]
#1747566
02/08/15 03:17 PM
02/08/15 03:17 PM
OzHemi
Garden Grove, CA
Just use a gps speedo. Uses a small antenna.
What if you want to know how fast you are going in a long tunnel?
[Re: feets]
#1747568
02/08/15 07:50 PM
02/08/15 07:50 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
My Autometer can be calibrated. You can basically follow another car and drive exactly 2 miles, or you figure out the amount of pulses for that distance, then turn the sending unit until that number pops up on the screen then save.
With that being said, my speedometer runs off of magnets on the driveshaft using a magnetic pickup for a rostra cruise control kit, and a VSS buffer module for an 80's 5.0 TBI firebird. Works amazing.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#1747569
02/09/15 09:01 PM
02/09/15 09:01 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I run a great app on my iPhone called 'Speedometer'. Gives a dead on gps reading for speed and odometer distance,,,,among many other attributes.
Really handy to determine how far out of calibration you are when swapping tires, rear ends or even transmissions,,,,drive gears for speedometer cables often have differing tooth counts just as will driven gears.
