Please Help with spare tire question. #1747541
02/05/15 10:50 PM
02/05/15 10:50 PM
wyoming
steve817 Offline OP
steve817  Offline OP
wyoming
I have a 1970 Challenger R/T SE with a SPD of 10/1969. It has 15/7 inch Rally wheels and poly-glass tires. What is the correct spare for this ***NOT the SPACE SAVER***. 1) What does the rim look like, what would the correct numbers/letters be?
2) What size of rim?
3)What color of rim?
4) Does it use the same 15 inch poly-glass tire?
5) Will it fit in trunk if there is a rear window defogger with the speaker adapter?
6) what length rod with wingnut?
Pics are always welcome. Thanks, Steve
Re: Please Help with spare tire question. [Re: steve817] #1747542
02/05/15 11:06 PM
02/05/15 11:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
All E-bodies delivered with 15" tires got the space saver spare.
Re: Please Help with spare tire question. [Re: Alaskan_TA] #1747543
02/06/15 02:46 AM
02/06/15 02:46 AM
wyoming
steve817 Offline OP
steve817  Offline OP
wyoming
Thanks Alaskan TA. I have the bottle, bracket, short bolt, wingnut, white stem cap....now I just need a rim, inflatable tire, hook and I'm guessing tons of money. Anyone out there who has what I need? Thanks, Steve
Re: Please Help with spare tire question. [Re: steve817] #1747544
02/06/15 04:21 AM
02/06/15 04:21 AM
IN
ahy Offline
ahy  Offline
IN
One choice is correct or functional? A 15" steel wheel and matching size tire would fit and be functional as a spare. Sounds like the space saver is "correct" but I wouldn't want to run on one. I run a 17" spare to match my wheels/tires because I want to be able to roll on it as long as needed when needed.
Re: Please Help with spare tire question. [Re: ahy] #1747545
02/06/15 04:40 AM
02/06/15 04:40 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Not that it is correct or proper but can a modern space saver wheel work as a spare. I have a space saver from a jeep Cherokee and its about the same diameter and bolt pattern and it is a space saver just wondering if it would work.
Re: Please Help with spare tire question. [Re: joes68340s] #1747546
02/06/15 10:13 AM
02/06/15 10:13 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I have a full size in my AAR because I drive it. I had to finaggle it in and I'm not sure I can get it out if needed, it's a 235/70/15 on a 6.5 ralley.
Chalenger opening is much bigger than a Cuda's so you have a better chance.
Careful, your character's showing!
