learn me. dually vs single wheel #1747499
02/05/15 08:10 PM
02/05/15 08:10 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
92 1ton single axle vs 1ton dually. both conventional trucks not cab and chassis. whats the difference between the two diffs? is it hubs and studs or??
Re: learn me. dually vs single wheel [Re: chrisf] #1747500
02/05/15 09:45 PM
02/05/15 09:45 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
The dually will have longer studs to accommodate dual wheels and most likely use drums for coined rims and flat lug nuts.
And of course the hub extensions for the front.
Re: learn me. dually vs single wheel [Re: redraptor] #1747501
02/06/15 02:06 AM
02/06/15 02:06 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
Assuming this is Cummins, same as above, maybe a different width rear end...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: learn me. dually vs single wheel [Re: dynotune440] #1747502
02/06/15 03:14 AM
02/06/15 03:14 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
its cummins. its for a customer who wants to go dually. I assumed diff was the same just the hubs and studs were different.
found the info.
srw 53"
cab/chassis 55" 5/8" studs
Dually 60" 5/8" studs
Re: learn me. dually vs single wheel [Re: chrisf] #1747503
02/06/15 09:26 AM
02/06/15 09:26 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
'72-93
SRW 65" WMS
Dually pickup 72"~ WMS
Re: learn me. dually vs single wheel [Re: chrisf] #1747504
02/06/15 11:38 PM
02/06/15 11:38 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
found the info.
srw 53"
I have a 93 dually Cummins. the studs are 5/8". They are torqed at 350 foot pounds. Very annoying to change tires.
If you are going to change a srw truck to a drw. I would set it up using 94-02 parts and axles.
1974 Roadrunner
1967 Charger
Re: learn me. dually vs single wheel [Re: Saskabusa] #1747505
02/07/15 10:17 AM
02/07/15 10:17 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Front axle differences are the wheel hubs. There are not spacers on the older trucks like the 94 and up. 94 up front axles have almost nothing that swaps with the older style, nor is the newer axle swappable as a assembly. The good news is that lots of folks will trade srw hubs for drw hubs, me included...
There are 3 different rear axle widths for 93 and earlier trucks, iirc the widths were posted above. If you are running a flatbed the width isn't that critical but for a pickup bed you do need the widest axle so the inside wheel clears the bed.
I've heard but not confirmed that 94up srw axles are close to the right width for pickups.
Nothing wrong with the 5/8 studs on the dually axles
