Any early A bodies minitubbed? #174712
12/25/08 11:55 AM
12/25/08 11:55 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
Trying to get a measurement on the rearend. Axle flange to axle flange? I have a b body rear end that I am going to cut down and wanted a nuetral wheel.. You know equal off/in set...
Was wondering what yall had and Ideas... Pictures would be great also...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Any early A bodies minitubbed? [Re: Boosted] #174713
12/25/08 03:16 PM
12/25/08 03:16 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
This probably doesn't help, but my 72 Dart, mini tubbed, uses 24 inch axles. Stock is 28 inches. So It's 4 inches shorter on each side. I bought it with the cutting and tubbing already done.
Oh, and my wheels are not neutral, they are 10 inch with 4 inches to the mounting flange.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Any early A bodies minitubbed? [Re: fasteddie] #174714
12/25/08 06:29 PM
12/25/08 06:29 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
So stock frame rails... and a 4" in or outset rim? I am planning on 10" rims also.
2011 RAM3500
Re: Any early A bodies minitubbed? [Re: Boosted] #174715
12/26/08 02:18 PM
12/26/08 02:18 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
For my 66 Dart, I bought a set of 15 x 10 draglites with 4.5 BS. Tires are 315/60/15s. The rearend housing ended up being 46" and the drum to drum width is about 51.5 if I remember correctly. The tires fit like a glove.
Here is the car with some 325/50/15s. They weren't tall enough for my liking.
