Page 1 of 3 1 2 3
blown hemi questions ?? #1747073
02/05/15 04:19 AM
02/05/15 04:19 AM
Oh
His and Her 69's Offline OP
Oh
I am getting parts for a blown hemi motor as I can afford them and I have a couple questions.
I have a friend with a 6-71 Teflon stripped weiand blower and a bird catcher hat. He wants to sell it but what is a fair price for used parts? I want to street drive the car and race it some so dual purpose but not long distance driving just 50 miles or so each way.
(I know I will have to get the hat flowed for my application and check out the blower but it looks like new inside right now)
Will this blower be OK for street use??
Will it build too much heat street driving it??
If the price is right would you run this combo?? I will get the hat converted to gas use.
Motor is a 426 alum KB hemi water block 4.28 bore now, callies crank stock stroke, BME alum rods, mopar alum dual plug heads, no pistons or cam stuff yet, no intake yet.
Any ideas on cost or if this is a good or bad idea let me know.
I am doing this on a budget and I think I can get the blower and hat at a fair price since he has no use for it anymore.
Thanks Guys.
David
Re: blown hemi questions ?? [Re: His and Her 69's] #1747074
02/05/15 04:20 AM
02/05/15 04:20 AM
Oh
Oh
blower and hat photo.
the intake is for a big block chevy.
Re: blown hemi questions ?? [Re: His and Her 69's] #1747075
02/05/15 06:29 AM
02/05/15 06:29 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Man, that's an ancient setup. The blower will need a rebuild, I bet.
If you think that mechanical injection system is going to work on the street, think again.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: blown hemi questions ?? [Re: DusterDave] #1747076
02/05/15 07:31 AM
02/05/15 07:31 AM
Oh
Oh
I have no clue if the mechanical system will work that is why I am asking. Before I spend money on something I figured I would ask some of you guys what your experiences were.
I figured this was a Good place to get some answers.
The plan is to put the engine into a 36 ply coupe and have an old school look but still be able to drive it some to shows, etc.
Thanks for the info Dave.
David
Re: blown hemi questions ?? [Re: His and Her 69's] #1747077
02/05/15 07:55 AM
02/05/15 07:55 AM
SW WI
cudacustoms1 Offline
SW WI
That setup looks like it has been seting for a very long time. I don't know what he is looking to get out of it but I hope it is not alot. Look things over really good. Watch for cracks,pitting etc. Are you shure it is striped? The hats don't work very well on the street they don't like part throttle. If you can get it for a good price you can buy it ,clean it up and efi it or sell off the parts you don't need to get the ones you do. I would need to have it looked at and probly gone thru by a good blower guy. Good luck
Re: blown hemi questions ?? [Re: His and Her 69's] #1747078
02/05/15 11:51 AM
02/05/15 11:51 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think you could save a lot of trouble by going carbs.I had my blower checked at SSI here in Brook Park at a good price.
Re: blown hemi questions ?? [Re: Clanton] #1747079
02/05/15 12:06 PM
02/05/15 12:06 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If your not saving 70% over a new shiney one i'd pass.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: blown hemi questions ?? [Re: His and Her 69's] #1747080
02/05/15 12:07 PM
02/05/15 12:07 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Hemi, blower, mech. injection, budget. I am not sure that those words can be put together.
I agree with above, that the mechanical injection won't work for you on the street. Now except for the budget part, you could use the hat as a throttle body and put modern fuel injection on it. But you will need to put the injectors above the blower to lube it. Ideally, a set of injectors above and below would be the way to go. But again with the costs.
I looked into doing this very thing. Talked to Rich Nedbal a couple of times about it. It was just too much money (and a good bit of complexity and tuning) for me.
But it can be done.
Master, again and still
Re: blown hemi questions ?? [Re: His and Her 69's] #1747081
02/05/15 12:57 PM
02/05/15 12:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Best to start out with something fresh setup and flowed for your motor.
As far as mechanical injection, I have run 5 different mechanical injectors on 5 different motors all drag racing. 3 N.A.
If you know what your doing it can work on the street. It can't be setup like you would for drag racing because it would be too rich. It has to be rich for the launch. Not so for the street. I know how to taylor the fuel curve. Yes it would be more hassle running it on the street but can be done.
My later setups had a primer pump so I didn't have to dump raw fuel into the hat to start the motor. I drove these motors all around the pits and know I could out run any carbs no matter what.
It would be a very steep learning curve for newbie on the street though.
I learned most of what I know from Kinsler fuel injection, Tom Conway and running my cars. Kinsler has some very good info you should acquire and read many times if you want to go injection which is way better on top of a blower. But maybe not for the street.
When I ran injection NA I was the one of the fastest guys at every race and qualified #1 many times and WON races racing quick 32 races. Spitzer and Jegs super quick series also. Mechanical injection is real performance, makes my blood flow.
I have plenty of mechanical fuel injection parts today in my shop and someday I plan to run it on the street in a 440 challenger.
1992
1999 or so.
This 572" motor went 4.80s by the time I was done with it. I was the 11th member of the Spitzer 4 second club with 4.90 with this car and motor in 1992 or so.
Re: blown hemi questions ?? [Re: His and Her 69's] #1747082
02/05/15 03:58 PM
02/05/15 03:58 PM
That blower is to small for your motor I've dyno tested more han one blown street motor, you need a 10:71 to start with if you want to make more than 850 hp Call all the good blower makers, NOT BDS and ask them for a size suggestion for your application Let us know what you find out
Re: blown hemi questions ?? [Re: His and Her 69's] #1747083
02/05/15 04:18 PM
02/05/15 04:18 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have a BDS airloc 8-71 with 150 runs on it if you want to try it while you are shopping for what you want.lmk.
Re: blown hemi questions ?? [Re: His and Her 69's] #1747084
02/05/15 06:47 PM
02/05/15 06:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
I also ran nitro methane in my injection, up to 10-12% nitro. That is a kick in the azz and the nose. Plus it made my car much louder, we had a blast at those races. Can't do that with carbs.
8-3" buttleflys out flows any carb setup.
Re: blown hemi questions ?? [Re: Challenger 1] #1747085
02/05/15 09:13 PM
02/05/15 09:13 PM
Speaking from just a little experience, piecing a blown hemi motor together has proven very costly many a $$ wasted. I had Dan (performance only) doing the build and even discussed with him before buying parts and when he received them I know he didn't even bother looking at them because they turned out be sh!!t or the wrong part. I have bought parts from members that turned out to be sh!t and am not in a position to argue because Dan is gone. I bought a used blower and was told it was great and everything was redone, had it shipped to Littlefield and turned out it needed a new snout, restripping and a few other things. If you are a newbie like me save yourself the grief and a lot of money and just deal with a reputable builder as close to you as possible, even if it's just for buying the parts but be careful because even with a builder you can still be taken for a fool.
Re: blown hemi questions ?? [Re: ] #1747086
02/06/15 01:07 AM
02/06/15 01:07 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I'm sorry you had a bad experience, but that's NOT the Dan I knew.
Re: blown hemi questions ?? [Re: DusterDave] #1747087
02/06/15 05:46 AM
02/06/15 05:46 AM
Oh
Oh
Thanks for all the info guys.
I thought that being the hemi is only 426 cubes that the 6-71 would be OK since I am not trying to set any track records with the car.
What size would be Good then ?? a 10-71 seems big to me Cab. (850 HP in a 3000 lbs or less coupe should be fast enough)
I know the parts are Good as I bought the crank and rods brand new and they have been checked out and ready to use.
The hemi has been checked out and just needs minor work.
The heads have been flowed and they flow 331 on the intake side which is on the small side in my opinion. They will need the normal valve work done on them.
Thanks Mike for the offer but I am a long ways away from needing the engine. I just had these blower parts offered to me and want to know if they were useable for what I want to do. I like to save money where I can but I also don't like to waste it on stuff that won't work for me either. This is why I wanted your opinions.
A friend had these parts for his race car but his engine long block stuff got stolen and he is done with trying to run fast.
Anymore info will be Appreciated and I will answer any questions I can.
Thanks, David
Re: blown hemi questions ?? [Re: His and Her 69's] #1747088
02/06/15 08:54 AM
02/06/15 08:54 AM
SW WI
SW WI
How much did your friend think that setup was worth?
Re: blown hemi questions ?? [Re: ] #1747089
02/06/15 10:31 AM
02/06/15 10:31 AM
Cincinnati, Ohio
Cincinnati, Ohio
Very good advise, trying to save a buck up front always cost you more in the long run.
Plus it takes all the fun out of it early on. Spend the money up front and you will be fun and money ahead.
Re: blown hemi questions ?? [Re: His and Her 69's] #1747090
02/06/15 11:21 AM
02/06/15 11:21 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thanks, David
David my offer will stand for later also.You only need intake,idler pulley,snout,carb linkage,I have the blower,carbs/base,pullays[crank,blower]blower belt just sitting on the shelf.
Re: blown hemi questions ?? [Re: His and Her 69's] #1747091
02/06/15 01:01 PM
02/06/15 01:01 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
I won't pretend to know as much about blown Hemis as others here, but my combo was originally put together by DLI as a race package. He spec'd a 10-71 on this 505" engine. So, based on that, I wouldn't think that a 6-71 would be too bad on a non-race 426.
Don't the 10-71s have a bigger base than the 6-71? Are there intakes still out there for the different blower bases?
I had never done this before either and needed parts, pieces, and advice on how to convert this combo to a street car. I was also concerned about not getting ripped-off. Of all the places I contacted, Good Vibrations in California was the best to work with and was where I got almost all my stuff. I would highly recommend that you contact them if you go this route.
http://www.goodvibesracing.com/
Re: blown hemi questions ?? [Re: DaveRS23] #1747092
02/06/15 01:18 PM
02/06/15 01:18 PM
Maryland
gofastboater Offline
Maryland
IMO a 6-71 will be too small, 8-71 would be just right. To be safe you could always run it underdriven. EFI would be the way to go. Hilborn, Enderle and others have a setup that fits in the hat. It's hidden and other that the 2 fuel lines, nobody can see it. I'm in the process of doing a 572" 16 plug hemi with a 10-71 and the 16 injector BDS EFI for the street. I can't get any pics to load so you'll have to use your imagination. LOL. If you have any questions try going to alkydigger.com and talk to Mike Chilando. He knows his stuff.
Page 1 of 3 1 2 3
