2011 Ram hemi swap? #1746962
02/05/15 01:14 AM
02/05/15 01:14 AM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So I got a friend with a 2011 Ram 2500 looking for an engine (crappy powdered metal rod snapped), is there one that swaps directly in that is any upgrade? Looks like the same part number for 2010-2012 (the only local used ones cost as much as a brand new short block and heads from dodge dealer), will an 09 or 2013 and newer bolt in without changing a bunch of stuff? What does it take to drop in a newer 6.4?
I don't mind swapping intakes and such on a used engine but don't want to mess with heads cranks...
Re: 2011 Ram hemi swap? [Re: HotRodDave] #1746963
02/05/15 01:16 AM
02/05/15 01:16 AM
Kalispell Mt.
Kalispell Mt.
Oh yeah, what about any of the car engines?
Re: 2011 Ram hemi swap? [Re: HotRodDave] #1746964
02/07/15 12:29 AM
02/07/15 12:29 AM
Kalispell Mt.
Kalispell Mt.
Any one?
Re: 2011 Ram hemi swap? [Re: HotRodDave] #1746965
02/07/15 01:06 AM
02/07/15 01:06 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
the 6.4 truck engine has an egr valve and an egr cooler under the intake. need to change many things, timing cover , intake, exhaust manifolds.
some 5.7 have mds, some don't, computer issues to deal with, some also have variable camshaft timing at the cam sprocket. I do know what is different,I'm not sure the exact years and models that fit what.
Re: 2011 Ram hemi swap? [Re: HotRodDave] #1746966
02/17/15 10:52 AM
02/17/15 10:52 AM
Ohio
john55 Offline
john55  Offline
Ohio
I am trying to do the same with an '09 1500, same as yours... crappy rod broke, went thru the block, so I'm looking for a block, 5.7 vvt, or 6.4 w/ vvt, still trying to decide or what I find...a reman 5.7 shortblock is 1100-1200, hoping I can find a decent block, then stroke w/good rods, and a set of 6.4 injectors...I think...
The Plymouth Win You Over Beat Goes On
