Re: Just picked up a thermoquad on e-bay
[Re: dmerc]
#174656
12/25/08 12:42 PM
12/25/08 12:42 PM
RapidRobert
great. Cant hardly go wrong for $75. You gonna open it up & check the float level & see if it's clean inside or was it wrapped up.
[Re: dmerc]
#174658
12/25/08 01:59 PM
12/25/08 01:59 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I'm hopping and waiting for a GREAT DEAL someday for a 6322 TQ carb under conditions you described ...
[Re: NachoRT74]
#174659
12/25/08 02:14 PM
12/25/08 02:14 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Nacho has a good point, $75.00 is a good buy for any new carb, but how useful it will be to you will depend on your application. Smog era TQ's are not a great carb out of the box for any kind of performance application, here are some notes from fellow board member Demonsizzler's website, he does a good job of explaining why. If you bought an earlier model (also explained on Demonsizzlers site) you'll have made an even better buy The 75'-84' smoger models
-------------------------------------------------------------------------------- In 1975, the carbs tops/bowls were changed. This was the end of the non smoger carbs and the begining of the smoger carbs, the first of the 9000 series. *The acception is the 1974-1977 Mopar Truck 440 cu in carbs which were based on the 1974 carbs. For the first time, very lean circuitry was used for less exhaust emissions, rendering these carbs poor performers on non smoger engines. These carbs have a distinctive vertical flat boss on the front center of the top plate which remained through 1984 and were again available in 800 and 850 cfm's. The 1976 carbs were the same as the 75's but for the first time, used a vacuum solenoid attached to the vertical boss on the front of the top plate. Some of these carbs did not have an idle speed screw or a vacuum port for the distributor vacuum advance on the Mopar lean burn ignition. I.H. used the carbs through 1979. This same design was used through early 1978 and again changed in late 78' through the final run in 84'. Many changes took place on the late 78' to 84' carbs due to smog regulations including electric idle enrichment solenoids added to the vertical flat boss on the front of the top plate and extra ports added to the base plate and even leaner circuitry. In 1979, a final aftermarket T.Q. was available and is known as the SuperQuad, only available as an 800 cfm with the integral 12 volt choke like the 74' Ford carb had. This S.Q. carb was a direct replacement for all oem carbs and was part # 9800/9810, non egr/egr for Ford, GM and I.H. engines and 9801/9811 for Chrysler non egr/egr engines.
[Re: ScottSmith_Harms]
#174660
12/25/08 06:24 PM
12/25/08 06:24 PM
Posts: 13,577 md
mopars4ever
md
[Re: dmerc]
#174662
12/25/08 07:03 PM
12/25/08 07:03 PM
Posts: 1,061 New Mexico
dmerc
New Mexico
[Re: dmerc]
#174663
12/25/08 07:08 PM
12/25/08 07:08 PM
dmerc
New Mexico
[Re: dmerc]
#174664
12/25/08 07:10 PM
12/25/08 07:10 PM
dmerc
New Mexico
[Re: dmerc]
#174666
12/25/08 09:22 PM
12/25/08 09:22 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Of course. Its directly in front of the front vent pipe, between the two front screws. Its where the I.E. valve would be
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#174667
12/25/08 09:33 PM
12/25/08 09:33 PM
Posts: 3,504 DFW
mr_340
DFW
The last TQ I bought was one from Koffel. It was listed as a 9801S, but turned out to be a 9000 series, regular production carb. I ended up keeping it anyway, but still was disappointed. Some guys don't know TQs very well, particularly the old Chrysler racers. I had a conversation with McCandless many years ago and was discussing the SB rocker shafts and he didn't know the 273 shafts had the oiling groove in them. They may know Hemi's real well, but some of the lesser engines they never messed with them at all.
Floyd Lippencott IV
[Re: mopars4ever]
#174668
12/26/08 10:28 AM
12/26/08 10:28 AM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
Is it a lean burn carb?
Not from picture,lean burn has no idle speed adjustment on throttle shaft.
[Re: I go fast]
#174669
12/26/08 10:54 AM
12/26/08 10:54 AM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
That carb has no timed vacuum port for vacuum advance, but even if you would decide you dont want to use it, many of the parts have value. (new floats, needle-seats, metering rods, jets, choke pull off, bowl) The early and late bowls are not interchangeable though.
I purchased some earlier style reman carbs a while ago. Early bowls are no longer available, and when they were, some where priced well over $100)
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#174670
12/26/08 11:33 AM
12/26/08 11:33 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
About 15 years ago one of the mopar mags showed how and where to drill and install a vacuum port for vacuum advance on a smog thermoquad. Very very easy. I think it was done by Rick Ehrenberg..Spelling?? The green brick guy.
Keep old mopars alive.
[Re: RapidRobert]
#174672
12/26/08 01:00 PM
12/26/08 01:00 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You can also install an idle speed screw, drill and tap a hole through the boss.
The vacume advance slot is still in the throttle plate you just drill a hole where the factory vacume port is and it goes into a chamber already in the casting and press in a tube to atatch a vacume hose.
