67 Satellite Gauge problem - you help with my tach
#1746106
02/04/15 01:28 AM
02/04/15 01:28 AM
Posts: 35 Toronto, Ontario, Canada
Big Den
Alright all you skilled mechanics out there who helped me with my tach problem. I am going to test your skill some more. Here is my last electrical problem ( I hope). My temp gauge and fuel gauge do not work. Nope not the problem you think. I know immediately we think of the voltage limiter. Nope, replaced and still they did not work. Tested the new limiter and it did not work, reinstalled the original and it tests fine (blinking light on test light) so not the limiter according to the shop manual (and we know it will not be wrong ). Did not change anything with either one of them. Took out the circuit board, tested all circuits and they all work including the ground. Wire to the temp sender is contacting. Checked the temp unit is grounding, it is. Replaced the temp sender unit. Replaced the temp gauge with another tested gauge. All I can get is about 1/8 of an inch of response from the needle on the gauge when operating temp reached. Installed aftermarket gauge and operating temp is right up to where it should be. Really not sure what else to check unless the ground is not working properly after the dash cluster is reinserted. Gas gauge. Yep replaced the ground strap at the tank and tested it is grounding. Check lead wire to sender unit. Had unit out of tank and is showing it is contacting the resister and showing ohms variation as you raise and lower the float. Back to dash, replaced gauge with a working one, checked circuit board - ok. Strange that it is only those two gauges and both on the same side of the dash and both use the voltage limiter. Only thing I can think of now is the voltage limiter is not making contact inside the printed board when you insert it so current is reaching the limiter but not the gauge. Anyone had this stubborn problem. I think a ground problem. Guess my question is, if the limiter is testing properly when dash all installed, then the ground must be working for the cluster. There is no ground wires for the cluster so figure it must ground through the screws that hold the cluster into the dash. Very hard to test after the cluster is in. HELP
Re: 67 Satellite Gauge problem - you help with my tach
[Re: Big Den]
#1746109
02/05/15 02:53 AM
02/05/15 02:53 AM
RapidRobert
switched 12V current goes the the VL & is reduced to a pulsed ~5V then to the respective input terminal(s) on the temp and gas gauge(s) then from the "out" terminal on each gauge downstream to the respective (eng block/gas tank) senders. hot temps/full tank lets more current thru moving the gauge needles further to the right toward H/F. I wasn't quite sure where to start on yours' so I just thru some stuff out there to get us started & get it pinned down a bit. Nah I ain't going nowhere, it's too cold and I'm too lazy
[Re: RapidRobert]
#1746111
02/07/15 04:02 PM
02/07/15 04:02 PM
Big Den
here is the results and my opinion based on that. Temp unit cold - 1.06 ohms stud to hex, 1.06 stud to block, 0 hex to block
Temp unit hot - .10 ohms stud to hex, .10 stud to block, 0 hex to block
I have another gauge her and a VL and hooked it up to the temp wire and gauge worked fine, tested the VL at 5 volts. When I hooked through the temp unit, gauge moved about a needle width. I checked and there are two different senders for that car, one for gauges and one for idiot lights. I have ordered a new sender for gauges and see what that does.
Fuel gauge. Again VL working. Tested wire as you suggest by splitting the block under kick panel. I tested wire from sender to block and continuity is there. Tested the ground again at the sender, working. I then tested the upper block wire to gauge and the gauge worked fine by grounding the wire. Put block back together and tested circuit through the block, working. So gauge, ground, wire and VL working so it appears the sender in the tank is the problem.
Does this compute with you as being the summary of results.
[Re: Big Den]
#1746113
02/08/15 12:50 AM
02/08/15 12:50 AM
RapidRobert
I'm glad you stumbled on the fact that the wrong temp sender was in there as even with your (posted) readings I might not have caught that. On the tank if you (1) pull the blue wire L connector off of the sending unit threaded stud and ground the female connector to a KNOWN good ground & the gas gauge pegs (key on) then the problem is at the sender. (2) plug the female L connector back on to the threaded nipple & key still on & run a ground from the sender short metal nipple to batt neg or a KNOWN good ground & see if the gas gauge reads correct. If you peg the gauge do so as briefly as possible just long enough to confirm what it is doing. (3) if so get one of those short metal factory pieces with clips on each end to connect the nipple to the metal fuel line a few inches away to restore the ground (4) if no reading then siphon some gas & pull the sender. (5) you might ohm the threaded nipple to the sender round circular flat before you pull it & see what you get & note how much gas you have in there right now
[Re: Big Den]
#1746117
02/08/15 04:28 PM
02/08/15 04:28 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Goes to show, test test test before busting the buns.
Nice phrase! may I feel free to quote that? BTW - what and where on the sender if I may ask?
[Re: RapidRobert]
#1746119
02/16/15 01:50 AM
02/16/15 01:50 AM
Big Den
Hi Rapid Robert. DON'T YOU DARE LAUGH AT ME. :) Just wanted to update you on my progress for solving my gauge problems. Temp working fine. Gas gauge working, sender not working. Well I thought that. Bought a new sender, got the old one out, installed new one (tested first to make sure working). Reinstalled tank ( dropped it just enough to be able to replace the unit, not all the way out so did not spill gas) and hooked up new sender. Gauge not working again. Damit what is wrong. Tested again and again. OH CRAP, IT'S OUT OF GAS OR TOO LOW TO READ - HA HA HA HA . Now I think that is the dumbest thing anyone on this site has done. I checked the old original one and it works fine that is what tipped me to the fuel empty thing. Now I have a fully working OEM sender unit for a 67 Satellite to sell. Gosh it has to be worth at least a couple of hundred dollars after all the work I did. And thanks again for your help on everything. Now you can stop laughing.
Big Den, Looking for 67 VIP Plymouth parts
