Easiest way to remove Steering Box on E-Body? #1746099
02/04/15 12:06 AM
02/04/15 12:06 AM
Georgia
Steve Bryant Offline OP
Georgia
After watching some videos and looking around, it seems like removing the torsion bar and starter is the easiest way to get the Power Steering Box out of my 440 Cuda.
If I do that, I don't have to remove the battery, radiator overflow, exhaust manifolds or loosen a motor mount and lift the engine.
Anyone know a better way or does this plan make sense?
Re: Easiest way to remove Steering Box on E-Body? [Re: Steve Bryant] #1746100
02/04/15 11:57 AM
02/04/15 11:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
When I did the one in the Hemi cuda, I pulled the battery and tray, lifted the engine slightly and took the steering box out the top..
I wouldnt think with a 440 and stock exhaust you would have to remove the torsion bar??? ,,,,,,MAYBE the starter ??
Re: Easiest way to remove Steering Box on E-Body? [Re: gtx6970] #1746101
02/04/15 12:42 PM
02/04/15 12:42 PM
Georgia
Georgia
Thanks for the response. I will lift the car, remove the starter, take the linkage off the pitman and see what I can do. I can get the torsion bar off in about 2 minutes but I will hold off and see if I can get it out with just the starter removed.
Thanks again for the response.
-Steve
Re: Easiest way to remove Steering Box on E-Body? [Re: Steve Bryant] #1746102
02/04/15 09:12 PM
02/04/15 09:12 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I wnt the opposite way, manual to auto. Here's the link. I didn't have to remove the torsion bar, but my batteries are in the trunk. You'd have to remove that. I did all this around 2" headers.
A Arms and steering box.
Re: Easiest way to remove Steering Box on E-Body? [Re: Cudajon] #1746103
02/04/15 09:42 PM
02/04/15 09:42 PM
Georgia
Georgia
CudaJon, thanks for the post. It sounds like you removed the battery and then lifted the engine to give you the room needed to remove the box. This is what Firmfeel told me as well and they suggested that I may also have to remove the exhaust manifold.
Re: Easiest way to remove Steering Box on E-Body? [Re: Steve Bryant] #1746104
02/04/15 10:30 PM
02/04/15 10:30 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
If you can get the Powerbox out putting the manual box in will be easy. The manual box is much smaller. The hardest part for me was torquing the bolts down. Like I said I did this around 2" headers which are a lot harder than the stock manifold. Good luck. My batteries are in the trunk.
