new charger wheels on an old charger??? #174361
12/25/08 12:09 AM
12/25/08 12:09 AM
ne ohio
garymendy Offline OP
ne ohio
will any wheels that come stock on a new charger fit a '69 charger. I saw one add for and old charger with new charger wheels and it looked great..
the wheels where on the back..
has any one tried this? what size works if it does???
thanks
garymendy@yahoo.com
Re: new charger wheels on an old charger??? [Re: garymendy] #174362
12/26/08 11:16 AM
12/26/08 11:16 AM
Indiana
swepty Offline
swepty  Offline
Indiana
I don't see why it won't work. The new wheels are 5x4.5 bolt pattern. They are 18" and I happen to need to get rid of a set. I have a complete R/T set that are the polished split 5 spokes with brand new directional toyo proxes tires 255/50/18. They fit my dakota but rubbed when I turned.
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck 1986 Power Ram 400hp 360 6" lift 1970 Plymouth custom suburban 318 4" drop 1996 Dodge 1500 360 4wd 3" lift North Central Indiana Mopar Club member
Re: new charger wheels on an old charger??? [Re: garymendy] #174363
12/26/08 12:05 PM
12/26/08 12:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Too big and too much offset. bolt pattern is the only thing the same. If you like the 17-18" look there are many aftermarket wheels made.
Re: new charger wheels on an old charger??? [Re: Mr.Yuck] #174364
12/26/08 01:49 PM
12/26/08 01:49 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I swapped mine.....using PhotoShop though
The 20"s look out of place on the '69 but the 15"s look cool on the '08
1MYTGTX
Re: new charger wheels on an old charger??? [Re: 1MYTGTX] #174365
12/26/08 01:51 PM
12/26/08 01:51 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I did see these on an E-body at Carlisle last year.....
1MYTGTX
Re: new charger wheels on an old charger??? [Re: 1MYTGTX] #174366
12/26/08 04:55 PM
12/26/08 04:55 PM
Tampa, FL
Saint Crispan Offline
Tampa, FL
Ugh.
Just because you can do something, it doesn't follow that you should.
Re: new charger wheels on an old charger??? [Re: 1MYTGTX] #174367
12/26/08 05:23 PM
12/26/08 05:23 PM
Vista, CA
71Chip Offline
71Chip  Offline
Vista, CA
That barracuda might look good without those mud flaps
71 Challenger
Re: new charger wheels on an old charger??? [Re: 71Chip] #174368
12/26/08 05:29 PM
12/26/08 05:29 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Yeah, and have you seen that mole on [insert generic hot girl's name here] back? Ugh!
Re: new charger wheels on an old charger??? [Re: 1MYTGTX] #174369
12/26/08 07:37 PM
12/26/08 07:37 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Only thing that would look better is a set of D's
Re: new charger wheels on an old charger??? [Re: Saint Crispan] #174370
12/26/08 07:39 PM
12/26/08 07:39 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Ugh.
