Need to start my son's car in trailer #1743240
01/31/15 04:37 PM
01/31/15 04:37 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
And move it inside, but it's 10 degrees out and it has aluminum rods with 15:1 compression. Is there any risk hurting anything inside the motor?
He needs to make some changes and it looks like more snow tomorrow so I want to take advantage of the sunny day today.
Re: Need to start my son's car in trailer [Re: Sammy] #1743241
01/31/15 04:47 PM
01/31/15 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt fire it up without putting heat in the engine..
back the trailer up in front of the garage and push
it out and into the shop
Re: Need to start my son's car in trailer [Re: Sammy] #1743242
01/31/15 04:47 PM
01/31/15 04:47 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I wouldn't start it. The oil is going to be like syrup. It isn't going to want to run. If you HAVE to start it, but a heater in the trailer and heat it up really good before doing so. But, then you have a chance of setting the trailer on fire, you know Murphy is hanging around.
I would push it into the garage instead of starting it.
Re: Need to start my son's car in trailer [Re: Sammy] #1743243
01/31/15 04:49 PM
01/31/15 04:49 PM
Milwaukee WI
R_Blaha Offline
R_Blaha  Offline
Milwaukee WI
What is the oil weight in the car? 50w or 20w-50 I wouldn't start it. You would be better off backing the trailer by your garage, getting a case of beer, and calling some friends over to push it out, then drink said beer!
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: Need to start my son's car in trailer [Re: R_Blaha] #1743244
01/31/15 05:36 PM
01/31/15 05:36 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
That's the way I have to do it!! Can't get any "friends" around without beer. Will be getting mine out of the trailer in a few days to install my new Thumpered carb.
If you like drag racing, support your local track.
Re: Need to start my son's car in trailer [Re: CHAPPER] #1743245
01/31/15 05:44 PM
01/31/15 05:44 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Spun the bearings out of one doing that. Put a heater under it or something.
Re: Need to start my son's car in trailer [Re: CHAPPER] #1743246
01/31/15 05:46 PM
01/31/15 05:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Put a torpedo heater in the trailer and warm it up a few hours. Mine won't even start when it's that cold. I have found throwing a fender cover over the carbs helps.
Doug
Re: Need to start my son's car in trailer [Re: Sammy] #1743247
01/31/15 09:59 PM
01/31/15 09:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well the Sunny day is over. I hope you found some friends to just help you push the car in the garage. I wouldn't start it, I don't see the need. There are other options.
No on the Torpedo heater also, they get hotter then most think. Guy burnt his motor home down trying to thaw some water tanks before he got it winterized just a few blocks from me. Heard other similer stories as well.
Re: Need to start my son's car in trailer [Re: Sport440] #1743248
01/31/15 10:50 PM
01/31/15 10:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No on the Torpedo heater also, they get hotter then most think. Guy burnt his motor home down trying to thaw some water tanks before he got it winterized just a few blocks from me. Heard other similar stories as well.
I certainly wouldn't leave it unattended. I have used one in the trailer with good results but paid attention to where it was pointed and stayed with it. Last year I had to rebuild the inner roof structure of my trailer during the winter. I would have froze to death. Glad you got it moved.
Doug
