Which Subframe Connectors?
#1743219
01/31/15 04:12 PM
01/31/15 04:12 PM
Posts: 5,161 CT
GTX MATT
CT
Which sub frame connectors are best to use on a street/strip car and why? Currently after a hard pass from a roll on the street my doors get hard to open and want to hang up.
Re: Which Subframe Connectors?
[Re: tubtar]
#1743221
01/31/15 05:46 PM
01/31/15 05:46 PM
Posts: 4,206 New York
polyspheric
New York
X2 - the 3" height is where the stiffness comes from.
Boffin Emeritus
[Re: GTX MATT]
#1743223
01/31/15 08:25 PM
01/31/15 08:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you dont want to go through the floor you can still use the 2x3 but lay it up against the floor and use a set of dividers and set the dividers 1/8" more than the biggest gap between the tube and floor... keep the dividers 90* to to the floor and scribe the whole length.. cut on that line and weld it in (floor and all)... I normally cut the floor and have the top inside the car like the others have said
[Re: upnover]
#1743227
02/01/15 03:33 PM
02/01/15 03:33 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
us car tool are really nice, fairly light and they make the car look like a factory framed car when your done, they are cut to the contours of the floorboards and mine required minimal trimming to make them fit, very nice product.
They do look nice. Their effects as far as stiffening up the chassis are not even in the same ball park as 2X3 protruding through the floor pan behind the front seat. Same with 2X2 .......... you are improving the situation for sure. And it is much easier. But.............not optimum.
[Re: actionange]
#1743229
02/01/15 04:57 PM
02/01/15 04:57 PM
Posts: 5,161 CT
GTX MATT
CT
The car is a '67 Plymouth B body, 4 speed car. I'm not really a fab/welding person and was hoping not to cut the floors, but rather buy something and have someone weld it in for me, should have specified. I know its not optimum but should it hold up ok in a car running low to mid 11s with the stick?
Would that leave me with just the Hotchkis or the US Car Tool pieces?
[Re: GTX MATT]
#1743230
02/01/15 06:54 PM
02/01/15 06:54 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
I'll end up with uscartools when I get this done. The hotchkiss one is pricey,!!
[Re: GTX MATT]
#1743231
02/01/15 07:06 PM
02/01/15 07:06 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Has this car ever seen track time? How do you know it runs 11's? I ran 11's back in the day with a stick and didn't have sub frame connectors.
[Re: GTX MATT]
#1743232
02/01/15 07:08 PM
02/01/15 07:08 PM
MR_P_BODY
The vertical walls are what you are looking for.. so if you can, get as close to 3" vertical and maybe .100 to .125 thick
