Page 1 of 3 1 2 3
Post your Hemi stroker Build #1742700
01/30/15 11:32 PM
01/30/15 11:32 PM
Armada MICH.
DUSTER_340 Offline OP
Armada MICH.
Looking for build up ideas for a 68 super stock engine. Car will be an automatic mostly street driven and run on 94 octane. I want to use a factory type cross ram.
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742701
01/31/15 01:27 AM
01/31/15 01:27 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Well the last one was a 484 Hemi with 4.15 stroke and 4.310 JE pistons and 11.6:1 compression on pump gas with Indy 426-1 heads ported by me flowing 400cfm, and WP Iron block...In its hey day it made over +700hp, but I detuned the cam a bunch for more street use as it tended to eat parts....So I removed the .738 cam and pulled the efi off it, and went to a .590 cam and an SV1 carb and it made 660hp...Went a best of 10.74 thru the mufflers on pump gas
EFI and big cam....
Small cam and SV1....
My current build is an 11.25:1 all aluminum 605 Hemi with Indy alum block and Indy Hipo heads, aka Canfields, and it has a mild .685 mechanical cam and will have the injection back on it. Depending where the flow numbers on the heads fall, we should see +800-850hp out of this one...Purchased everything from BG Racing.
Re: Post your Hemi stroker Build [Re: Dragula] #1742702
02/01/15 12:16 AM
02/01/15 12:16 AM
Armada MICH.
Armada MICH.
Thanks for the information. Anyone else?
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742703
02/01/15 12:27 AM
02/01/15 12:27 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I'm in the process of my first hemi build. Muscle Motors is putting together a 605 Callis/Oliver bottom end, and I have yet to select the heads. I was leaning towards a single dominator as I already have some money invested in N2O plates for this flange.
I started a thread on here and yellow bullet. Several people have posted their combos (most are significantly above my HP goal).
Moparts - Which Hemi Head
Yellowbullet - Which Hemi Head
Re: Post your Hemi stroker Build [Re: gsmopar] #1742704
02/01/15 01:24 AM
02/01/15 01:24 AM
Dragula Offline
Dragula  Offline
I can tell you seeing people race a Hemi is rare, and seeing people race a Hemi on N2O is like seeing an albino deer.. They still do it, but after spending all that money, its not like killing a SBC with N20...Heck even getting the basic parts for a Hemi can be difficult let alone what your building.
Basically with your combo, I see a couple choices, the Indy Hipo, and Stage V....
Re: Post your Hemi stroker Build [Re: gsmopar] #1742705
02/01/15 01:39 AM
02/01/15 01:39 AM
Armada MICH.
Armada MICH.
Thanks for the link. This is my first hemi build as well, and I want to be able to make good choices, that are within my budget.
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742706
02/01/15 01:50 AM
02/01/15 01:50 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I would suggest you buy and read Rich Nedbal's book on building Max Performance Hemi engines.
http://www.amazon.com/How-Build-Max-Performance-Hemi-Engines/dp/1613250746
Mine is a pump gas 572" World alum. block Stage V heads.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Post your Hemi stroker Build [Re: Hemi Allstate] #1742707
02/01/15 01:59 AM
02/01/15 01:59 AM
Armada MICH.
Armada MICH.
Thanks, I just ordered it!
Re: Post your Hemi stroker Build [Re: Hemi Allstate] #1742708
02/01/15 03:21 AM
02/01/15 03:21 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Mark
I didn't care for that book. I was expecting something like Andy Finkbeiner's How to Build Max-Performance Mopar Big-Blocks, but the Hemi book kind of fell short.
Re: Post your Hemi stroker Build [Re: Dragula] #1742709
02/01/15 03:35 AM
02/01/15 03:35 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Mine will be at the track, but will likely without the bottle. My HP goals appear to be quite modest when compared to similar sized Hemi builds. At the rate I'm going I'll need a NHRA license and parachute without N2O. One of the MP or Indy crates probably would have been fine, but with the mixed reviews on this and other boards; I felt I could spend a little more and have a piece of mind. That some how turned into an aluminum 605.
Re: Post your Hemi stroker Build [Re: gsmopar] #1742710
02/01/15 09:39 AM
02/01/15 09:39 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I for one loved Rich's book, lots of great info in it. Dave
Re: Post your Hemi stroker Build [Re: quickd100] #1742711
02/01/15 11:33 AM
02/01/15 11:33 AM
pa
572charger Offline
572charger  Offline
pa
yes gsmopar u should be able to run some high 9s no problem my car weighed 3910 it ran 9.60 at 141.76 whith no spray and a single prosystems dominator on a ray barton intake on 93 octane sheetz pumpgas and et streets caltracs full exhaust !!!! im at 12:1 comp now it was 11.7 to one, dont, be afraid to put compression in it even for pumpgas !!! after all its a hemi !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Post your Hemi stroker Build [Re: 572charger] #1742712
02/01/15 12:59 PM
02/01/15 12:59 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Great info, thanks!!!
I'm a few hundred pounds lighter (3621 lb) with a iron wedge and factory K-member. I don't know how much I'll shed switching to Alterkation and this Hemi, but it looks like I'll be doing a chassis cert next year. Look for some chassis cert threads/questions from me after I get this thing back together.
Re: Post your Hemi stroker Build [Re: gsmopar] #1742713
02/01/15 06:01 PM
02/01/15 06:01 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Mark
I agree all the way. I read Andy's big block book first also. I did learn a few things and it was nice have some pictures. But the folks here have filled in most of the blanks.
I'm in the middle of building my Hemi. Its a 472. Stock iron heads, 10.5:1. Most parts came from ebay and Moparts so its been a pretty budget friendly build so far. I am in process of rethinking my cam choice and have several companies looking at specifying a cam for me.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742714
02/02/15 06:16 PM
02/02/15 06:16 PM
California
mickm Offline
mickm  Offline
California
mine is a mopar siamese block, 4.5 X 4.25. 7.1 inch 2.2 big end rods, CP pistons, came out at about 10.25 - 10.4:1 depending on the compression calculator i used. solid roller .605/.585 ~ 242@.50, 112 LSA. stage V heads prepped by tim at FHO. stage V intake with 2 650 edelbrocks. did 712 @ 6000. mine is a street car, hasn't seen the track yet, one of these days...
Re: Post your Hemi stroker Build [Re: mickm] #1742715
02/02/15 10:53 PM
02/02/15 10:53 PM
Armada MICH.
Armada MICH.
Thanks for posting would like to see some other combinations.
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742716
02/02/15 11:17 PM
02/02/15 11:17 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
I had Gary Stanton build mine. It's a world block 472. I stayed with standard bore and went with 4.125 stroke. This is a street motor that I just wanted a solid power plant that was a Hemi! They use Scat crank and rods. He also used Diamond pistons with 10.5 C/R. He used the new MP(Eddelbrock makes them if I'm correct) aluminum heads with 2.25 intake valves and 1.94 exhaust. I went with stock MP rocker gear. He put the biggest hydraulic flat tappet cam that comp grinds for him. I don't have the grind number handy, but it was a 108 LSA with around 580 lift and 249 duration @.050.. On top I have a street hemi 2-4 intake with 600 Eddy's. It dyno'd 583hp @6000 RPM. The cam should make power to 6500 RPM and since the Hemi's love RPM and hydraulic cams don't, we didn't pull any higher. The dyno pulls felt good with smooth power up to 6000. I wanted to be between 575-600 HP, and we seemed to achieve that. Gary seems to think we left some numbers on the table only pulling to 6K. All in all I'm okay with that.... Engine is going in my 70 Challenger with a Passon overdrive 4 speed, and a Dana with a 3.54 gear. So that'll be plenty of street pounding power for me!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742717
02/02/15 11:25 PM
02/02/15 11:25 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I hesitate to post on a "race" forum but here goes. I have a early Siamese block (2000) Callies 4.5" crank, 4.375 bore, 10.75 comp with port matched MP aluminum heads. Cam is .246/.254 @ .050 .585 net lift on 112 separation, solid roller. Stage V intake with (2) Holly 750 carbs, TTI 2" headers. We dynoed the engine and it pulled 635 HP @ 5900 rpm. BUT when I got it home and installed in the car, it didng't feel right so I checked TDC with a piston stop and checked against the tab where the engine builder set the timing. Care to guess? it was retarded over 10 degrees! They dynoed it at 32 degrees? I put a vacume gauge on it, set the initial, welded up the advance slots etc. I am now running a TRUE 35 degrees total and it feels MUCH stronger!
Still runs great on 93 pump with vacume advance bringing the total to 44 degrees under light load with no detonation. Car weighs 4,175 empty, 3,000 stall with 3.54 gear and GV overdrive. Just a street car though. If I was going to race, I would have started 1,000 lb. lighter. Can't beat it though in summer with the top down!
Re: Post your Hemi stroker Build [Re: Hemi ragtop] #1742718
02/02/15 11:27 PM
02/02/15 11:27 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
The "boat"
Re: Post your Hemi stroker Build [Re: Hemi ragtop] #1742719
02/03/15 12:33 AM
02/03/15 12:33 AM
Armada MICH.
Armada MICH.
Thanks for posting guys. I think this is the correct forum for this topic. I too will only be using my project for street use . So I really appreciate seeing street configurations.
Page 1 of 3 1 2 3
