Anyone used Lokar Kickdown and throttle Cables? #1742434
01/30/15 05:56 PM
01/30/15 05:56 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Has anyone used these on a big block mopar? What body, engine? Which length did you use? How did it work for you? Im seeing a lot of claims that they install easy and solve a lot of issues with throttle brackets and kickdown linkages, especially if you're putting a big block in an original small block car or any instance when you dont have the right oem linkages.
Im seeing a lot of original linkages on ebay for $100 or more, thinking why not get a Lokar if they work even better and come with everything I need? The low end price for their cables is about $80.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Adam71Charger] #1742435
01/30/15 06:12 PM
01/30/15 06:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Put a kick down setup in a 1969 roadrunner hemi and single 4 barrel carb. I have no complaints with install or operation.
customer supplied all the parts so no idea on part number we used.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: gtx6970] #1742436
01/30/15 08:41 PM
01/30/15 08:41 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I like them a lot. Easy to install, reliable and functional. The adaptability is their best feature imo. I've used them on 4 Mopar builds over the last 13 years with zero problems.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Adam71Charger] #1742437
01/30/15 08:58 PM
01/30/15 08:58 PM
central il.
second 70 Offline
second 70  Offline
central il.
Yes 1970 Cuda 426 hemi 2-4 4-speed. I believe 24"
I just removed factory cable painted a large flat washer flat black to reduce the square hole in fire wall put it on cable and tightened. Can't even tell washer isn't part of cable. Works great. Mike
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: second 70] #1742438
01/30/15 09:07 PM
01/30/15 09:07 PM
IN
ahy Offline
ahy  Offline
IN
I run a Lokar throttle cable in a '70E. Installed about 10 years ago. BB with EFI. It installed eaisly and has worked fine. From memory I cut to correct length which was easy to do.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Adam71Charger] #1742439
01/30/15 09:11 PM
01/30/15 09:11 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Had one on the bracket car. After five seasons the cable frayed. Using a rod now.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Dabee] #1742440
01/30/15 10:02 PM
01/30/15 10:02 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I bought a truck that had a Lokar throttle cable.
I almost wrecked it on the way home do to a stuck throttle. The cable had sawed though the sleeve and was binding up. I put an OEM cable back on.
Rather than fight getting a solid kick down linkage to clear headers, I installed a Bouchillon KD kit on my '68 V100. It is heavy duty compared to Lokar and has the correct carb linkage to KD lever ratio.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: B5 Bee] #1742441
01/30/15 11:29 PM
01/30/15 11:29 PM
They have multiple options for sleeve material, do you remember which type you had? Does the bouchillon kit work on edelbrock carbs and manifolds?
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Adam71Charger] #1742442
01/31/15 12:49 AM
01/31/15 12:49 AM
scratchnfotraction Offline
x2 go with a Bouchillon kickdown cable with a stock throttle cable.
yes, they have a piece that goes on the carb throttle lever for a correct mopar ratio.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: scratchnfotraction] #1742443
01/31/15 01:23 AM
01/31/15 01:23 AM
Eastern WA
P
ProStock1320 Online content
ProStock1320  Online Content
P
Eastern WA
Lokar cables for the throttle & trans kick down on a 383/727 in a 56 Plymouth. I bought it that way. I've had nothing but problems with the hair thin trans cable. I have room for the factory rod linkage and may have found a set up but Bouchillon may be an option. Timely thread. Thanks.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: ProStock1320] #1742444
01/31/15 10:05 AM
01/31/15 10:05 AM
the house on the left.
cogen80 Offline
cogen80  Offline
i have used lokar throttle and kickdown cables on numerous times on different cars over the years.. never had an issue with them. install easy and work flawlessly for me. super smooth operating too.
if the cable is fraying then its installed wrong.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Adam71Charger] #1742445
01/31/15 03:32 PM
01/31/15 03:32 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
I had a lokar on my Duster. The kickdown was never right with it no matter how it was adjusted.
When I replaced it with a rod and adjusted it correctly I could see why. The geometry with the cable isn't there. You have two cables working in opposite directions where as your kickdown linkage has a slotted attachment at the carb for a reason, letting you be able to have much more adjustment.
Putting the rod back in and setting it up and the car shifted the way I always thought it should.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: PossessedDuster] #1742446
01/31/15 04:16 PM
01/31/15 04:16 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm using a Lokar cable on one of my cars and it works fine. The problem is if there's a mis-match between the length of the arm on your transmission and the pivot point on the carburetor end the adjustment will never be perfect. If I'm starting with a bunch on mismatched parts I use the Bouchillon set-up. It always comes out right.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: TooMany62s] #1742447
01/31/15 04:45 PM
01/31/15 04:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have a manual valve body so I just use the throttle cable. But this Lokar cable has been on my 63 since 2006 with no problems ever. Ron
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: 383man] #1742448
01/31/15 06:23 PM
01/31/15 06:23 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Be prepared to modify the kickdown cable ratio.
If you don't have the right length kickdown lever at the transmission end, modifications will be required.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Adam71Charger] #1742449
01/31/15 06:40 PM
01/31/15 06:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Anybody who is happy with their Lokar Kickdown either lucked into the correct lever ratios or is content with improper shift speeds.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: John_Kunkel] #1742450
02/01/15 10:03 AM
02/01/15 10:03 AM
moparx Offline
moparx  Offline
this has been my experiance as well. either late shifts, no shifts or early shifts. plus the cable seems to stretch very easily. one other thing i find troubling is the weak[by my standards] bracketry. the carb brackets as well as the transmission brackets seem to lack the strength and design necessary to not bend/move around without modification. when the weather breaks, i have a 72 duster to convert back to the original factory linkage because of the problems mentioned. in my opinion, a big waste of $85[what the owner paid for the kit.] these may work well on gm stuff[?], but i'll call junk every time on mopar applications. the transmission in this duster shifted perfectly using the stock linkage. it belonged to me, so i can testify to it's integrity. now, it's all over the place. time ran out last fall before winter's onset, or it would have been already replaced. luckily, there has been only 100 mi. or so run before parked, so i'm hoping the trans has not been smoked. and this couple are only interested in show poodles, so there were no beatings involved. for the record, i have had NO experience with the bouchillon kit, so i can't comment on that product.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: moparx] #1742451
02/01/15 10:21 AM
02/01/15 10:21 AM
PA
Sir Valiant Offline
Sir Valiant  Offline
PA
Can't stand my Lokar!! Putting in a manual valve body until I can get a manual 5 speed conversion.
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: Sir Valiant] #1742452
02/01/15 11:34 AM
02/01/15 11:34 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Maybe I'm just to easy but, My Lokar works fine
Re: Anyone used Lokar Kickdown and throttle Cables? [Re: babarracuda] #1742453
02/01/15 11:46 AM
02/01/15 11:46 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Never used their mechanical kick-down, but we use their throttle and brand X kick-down cables all the time. Beatiful product, nice quality, and in our applications, work perfect.
We used LoKar Throttle & K/D cables on the 454 swapped into this `84 Coupe deVille
`68 Barracuda 340-S
