Re: Brake Master Cylinder Related Question
[Re: Lefty]
#174240
12/24/08 06:13 PM
12/24/08 06:13 PM
Posts: 4,102 Cochise County Arizona
SPWC
Well looks like I may have jumped the gun. I went ahead and put the piece into the master cylinder,and then installed the master. I bench bled the master while on the car and then reinstalled the lines on the master. I pulled out all the bleeder screws,cleaned and reinstalled,and then applied pressure to the pedal,thinking that me pushing on the pedal (pushrod) would push it into the rubber piece. I hope im right!! Now im waiting for my stepson to get out of the shower to help me bleed the brakes.
[Re: SPWC]
#174241
12/24/08 08:45 PM
12/24/08 08:45 PM
RapidRobert
Is this MC a manual brake unit that has the machined recess for this piece to fit into. You'll have to take it out of the MC & slip it on the pushrod
[Re: SPWC]
#174243
12/24/08 10:43 PM
12/24/08 10:43 PM
SPWC
Yes it is a Manual Drum brake system on this car. Looks like im gonna hcve to undo everything again,luckily,its not that difficult. Wondering if I can do the roval without disconnecting the lines at the master,anyone ever try,without kinking the brake lines?
*EDIT*
I went ahead and unbolted the Master Cylinder and tried pulling it from the firewall,It wouldnt budge,so then I unhooked the brake lines going into the master and it came out a little,and wouldnt go anyfurther,whereas before with the old non functional MC the darn thing about fell off the firewall once I unbolted it and removed the lines.There was no rubber grommet on the old MC
Would anyone care to speculate,that my Pushrod is seated firmly(correctly) in the rubber groommet according to the description ive given above?
[Re: SPWC]
#174244
12/25/08 12:04 AM
12/25/08 12:04 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Pull the master cylinder and make sure it's on the pushrod.
[Re: SPWC]
#174245
12/25/08 10:55 AM
12/25/08 10:55 AM
Posts: 1,377 Back In Iowa
belv2vert66
Back In Iowa
*EDIT*
I would guess it is seated. One method of removing the rod is done basically just as you described. Loosen the master bolts as far as you can, place a spacer between it and the firewall and then go in and pull back on the brake pedal. Ironically, I just installed mine yesterday also, I spit on the grommet, installed it in the recess in the master, and then put the rod in. I did it on the bench tho. I considered putting the grommet on the rod first but I thought the sharp edges around the master recess and the edges of the grommet would be a bad combination.
[Re: SPWC]
#174246
12/25/08 11:02 AM
12/25/08 11:02 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
If you can't pull the rod out of the master cylinder, the little rubber grommet is doing it's job.... Depending on how your brakes are adjusted etc, the rod would/could slide right out leaving you with no brakes if someone pulled the brake pedal up if the rubber wasn't in there at all, hence the reason the engineers put it there. I put the grommet in the M/C making sure it was lined up properly and then assembled the rest. it snapped together when I pushed the brake pedal. It wouldn't pull out easily later when I had to remove the rod and M/C.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#174247
12/25/08 12:33 PM
12/25/08 12:33 PM
RapidRobert
Sounds like it did get seated the 1st time & my advice was in error. I had several where the pushrod would not slip inside the grommett when it was put in 1st,it just ended up jamming the grommet to the rear. Shove it back in there & if it locks you're good or if it's damaged a piece of vac line will work good. I apologise for the erroneous advice & the added work I caused you.
[Re: RapidRobert]
#174248
12/25/08 02:02 PM
12/25/08 02:02 PM
SPWC
No worries,better safe than sorry,seriously dont sweat it,we are all on a different level of experience.Heck I didnt even know what the piece was and thought of throwing it away.
[Re: sthemi]
#174251
12/26/08 11:41 AM
12/26/08 11:41 AM
SPWC
On a releated note, did you put the dust boot retainer on the new master in place of the stamped finger used on power brake cars?
There is/was nothing that resembles what you are talking about on the old or the new MC.
