Re: Drag radial questions
[Re: wedgeheaded]
#1742233
01/30/15 01:56 PM
01/30/15 01:56 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
The Nitto will last longer and be better in the rain, but the M/T will hook better.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: wedgeheaded]
#1742235
01/30/15 05:40 PM
01/30/15 05:40 PM
an8sec70cuda
I don't know how much power you have or how fast the truck should be, but the Nittos work very well on cars that run in the 12s or so. Some faster than that.
[Re: an8sec70cuda]
#1742236
01/30/15 08:03 PM
01/30/15 08:03 PM
Posts: 5,025 new jersey usa
11secdart
new jersey usa
I have M/T s on my D150 they work well, the truck runs low 15s with low 2.0 60 fts, I don`t really drive it in the rain.
[Re: wedgeheaded]
#1742237
01/30/15 08:20 PM
01/30/15 08:20 PM
Posts: 1,734 central il.
second 70
central il.
My thought too. I figured the Nittos would be better in the rain simply by having more tread. I can get the Nittos from Discount tire direct for $205. each, free shipping. M/Ts are about $230 from Summit. Basicly the same.
The nittos work well in rain and a nice ride on the street. Great everyday tire but I get zero traction on my hemi cuda.426 under 600 hp 4 speed 3:54 dana. Radials just don't work with 4 speeds. At the track I left at 1500 rpms and never moved had to shift into second just to move. LOL.
[Re: wedgeheaded]
#1742239
01/31/15 12:57 AM
01/31/15 12:57 AM
Posts: 15,487 Florida
scratchnfotraction
I use the A-body 8 3/4 , it tucks 12" x 4.5" backset rims with a 29x15x15 M/T Sportsman SR radial = 325/50/15 in the fenders. they wear great on the street, good wet weather traction = mine do daily use 100 miles a day x 4 yrs now. I just now have to watch it in the rain at speed. no burnouts either. the rubber compound is for DOT street use on cars/truck that are tubbed out to reduce wear with fattys tucked tight in turns. my 29x15.5x15 M/T Sportsman Pros only lasted 14 months daily driving same 100 mile route to work. wet weather sucked even when new. lot more traction than SR radial for hook up. I will be looking to go for another set of the SR radials in 1.5 yrs. and that is well worth the $ for fattys/longevity. IMHO
[Re: scratchnfotraction]
#1742240
01/31/15 11:55 AM
01/31/15 11:55 AM
Posts: 1,581 Friendly, WV
wedgeheaded
Friendly, WV
I like the looks of SR best but can get the best deal on the drag radials. Doe the SR tires have a deeper tread than the DRs? That would justify the extra price EZ enough. I found a set of new but never used SR 29/15.00/15 tires for $500 but it's a 3 hr drive each way. Besides, that's just a bit wider than I want. The 325/50/15 specs out at 13.5"
[Re: wedgeheaded]
#1742241
01/31/15 12:23 PM
01/31/15 12:23 PM
scratchnfotraction
I would think a drag radial is a softer compound rubber for more traction. not sure how that works out for street duty, wet weather, longevity. is that a DOT approved tire? I see a lot of street guys go through a few sets a yr but they do lots of burnouts showboating on the streets. I know the sportman pros were rated med to high horsepower and 20psi max on air pressure. I ran mine at 16psi and would drop to 12 psi to wrinkle the sidewall a little for max traction ( I could never break them loose on a launch LOL!) A M/T sportsman is what a lot of the t-buckets use for street duty and they are a hard compound rubber next to a sportsman pro. but the sportsman & sportsman pro do not like the wet weather at any speed. they hydroplane a low speeds 40 mph on my truck. IMHO, with 20 psi max air pressure/tubeless tires the extra $ for me was how long they have held up to daily driving on my truck. I think I am a little over 1/2 way on tred depth but not to the wear indicator yet. that's another thing to think about. tubeless or tubes??? the M/T pros called for tubes but I ran them tubeless without issues. same with the SRs. now I do like the squared edge look of the sportsman pro over the rounded edge look of sidewall on the drag radials or SR tires. the SRs are about 250$ a tire at the speed shop.
[Re: wedgeheaded]
#1742243
02/01/15 12:14 AM
02/01/15 12:14 AM
scratchnfotraction
IIRC, I looked up the SR on M/T web site. talked about rubber compound for wear. speed rating ect. talked about tubed out cars turns/tire scuffing/low wear compound. yes, it is a street tire not a drag tire. IMHO, it's a med traction tire for the street. Myself I have no NEED for a drag slick or drag radial other than LOOKS, so I do not run one on my truck. to me they look like a wet-weather tire you see on a INDY500 car. wide with the flame tred pattern.
#1742244
02/01/15 12:18 AM
02/01/15 12:18 AM
scratchnfotraction
another thing on the SR is weight of the tire. it is a heavy tire on the alum weld rim. 30-40 lbs the sportsman pro on the same rim was super light around 12-15 lbs might look at that on a darg radial while you deciding for a drag truck the lighter the wheel the better. I only mind the heavy SR when I R&R them.
[Re: wedgeheaded]
#1742245
02/02/15 01:32 AM
02/02/15 01:32 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Just another thought, use a 15x8 wheel with a real tire on it to drive on (could use a 275/60r15 for instance), switch over to the stickier tires when you go to the track. You have a truck, haul the tires there.
I have a set of 29.5x9 slicks in the back of the truck (stepside) still with plenty of room to put other things.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1742246
02/02/15 11:22 AM
02/02/15 11:22 AM
wedgeheaded
Friendly, WV
I have a set of AR TTs om my 75 Cordoba with 295/50s out back. I have thought about robbing it for now. I just think a truck needs a taller tire. It's a good thought and would free up some money for other things though.
#1742248
02/02/15 02:31 PM
02/02/15 02:31 PM
wedgeheaded
Friendly, WV
MAN! stop right there... dont ROBtake anything off the that Cordoba.
why would you do that?
I know. But, I have the motor out for a cam swap. I thought about putting the Doba motor into the truck to break in the cam. Might as well borrow the wheels too. It was just a thought. I've thought about selling the Doba but it's worthless. I have too many 1/2 finished toys. The Doba is safe, Probably.
[Re: wedgeheaded]
#1742250
02/02/15 04:39 PM
02/02/15 04:39 PM
scratchnfotraction
I don't think it is worthless. I would love to find a way to take it off your hands and give it good home.
#1742251
02/02/15 07:58 PM
02/02/15 07:58 PM
wedgeheaded
Friendly, WV
Thanks. I know it's not worthless but it would be hard to flip, and even harder to reclaim my investment. I dig it too much to bust it up. (forever)
