Vacuum and Mechanical Advance Differences? #1741696
01/29/15 04:11 PM
01/29/15 04:11 PM
NE
moparpoolman Offline OP
NE
With a 1972 400, What's the difference IF any between the Vacuum and Mechanical advance on a 4spd vs. auto. Also is there any difference with 2bbl vs 4bbl? Thanks
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741697
01/29/15 05:41 PM
01/29/15 05:41 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Good question. Basically that is what people say when they don't have a correct answer!
You'd think that there might be. When I am confused about an interchange, I look to RockAuto.com. Trouble is, so many auto parts stores go to a standardized part to cover multiple applications.
A 4 barrel 4 speed should have a different curve in the distributor with maybe less vacuum advance.
Re: Vacuum Advance Differences? [Re: Kern Dog] #1741698
01/29/15 06:21 PM
01/29/15 06:21 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
The Vacuum Advance Diaphragm Canister unit is (to some degree) adjustable using a 3/32-inch Hex (Allen) Wrench through the vacuum port opening in the unit.
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741699
01/29/15 09:22 PM
01/29/15 09:22 PM
NE
NE
With a 1972 400, What's the difference IF any between the Vacuum advance on a 4spd vs. auto. Also is there any difference with 2bbl vs 4bbl? Thanks
Also would like to add that I'm interested if there are differences in the original 1972 distributors with vac advance, not newer replacement distributors? Thanks
Re: Vacuum Advance Differences? [Re: D_C] #1741700
01/29/15 09:25 PM
01/29/15 09:25 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
I think some are fixed, and if you go in there with hex key, can puncture the diaphragm if you are not careful.
68 Roadrunner. 383 4-spd. Beat up.
Re: Vacuum Advance Differences? [Re: Mebsuta] #1741701
01/29/15 09:42 PM
01/29/15 09:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
adjusting the spring pressure on the diaphragm won't puncture the diaphragm. i do it all he time.
the real difference i've noticed in the canisters is the amount of degrees that are in them. the number of degrees in the canister is stamped on the arm that connects to the plate. they range from 7 degrees to 10 degrees (distributor degrees). i have noticed the lower degree canistrs having a slightly weaker spring.
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741702
01/29/15 09:46 PM
01/29/15 09:46 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
If you have a '72 FSM it will have the specs for both. You will then know if they were supposed to be the same or not.
Re: Vacuum Advance Differences? [Re: Mattax] #1741703
01/29/15 11:08 PM
01/29/15 11:08 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
It is physically different and has electronics wired to it also.
Ron
Re: Vacuum Advance Differences? [Re: RJS] #1741704
01/30/15 12:18 AM
01/30/15 12:18 AM
The electronic one retards when it is energized by the emission controls (same deal as the O tdc timing). Are you wondering about the differences or is your can shot & you are wanting to replace it? If so I'd suggest a regular (non electric) one and CCW with the 3/32" allen wrench slows the curve (doesn't change the total the can offers which is as said the number stamped on the arm) by requiring more vac for the same amt (deg) of advance. You can file the notch in the arm for more advance and epoxy strips of feeler gauge with JB weld on the back of the can to limit the arms' travel into the can to limit the total (either way as needed). I would set the initial then the total (initial+slots/no can) then springs then hookup/adj the can and (A) you want to stay just under the pinging point on your hottest/driest day at a steady (high vac) rpm such as an interstate cruise at or above the RPM where the springs are maxed out (full mech/vac adv) by altering the arms' travel then (B) with the allen wrench let the can come in as fast as possible staying just under the pinging point on your hottest/driest (most likely to ping) day in everyday driving under varying vac levels. alot of work but alot of gain to be had
Re: Vacuum Advance Differences? [Re: RapidRobert] #1741705
01/30/15 12:50 AM
01/30/15 12:50 AM
NE
NE
What I'm trying to figure out is if All the 1972 Distrbutors are all physically the same and maybe different internally(springs or weights) and if they all have same or different vac. adv. units (physically or internally). I have a 1972 400 4bbl auto and am Looking for an original Distributor. Do I need to buy one just for that application or can I buy a 2bbl or a 4spd one and make internal changes if they are different.
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741706
01/30/15 12:55 AM
01/30/15 12:55 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The distributor for your Road Runner is going to look the same 2 bbl or 4bbl.
The auto and 4 speed is going to also look the same except for the large vacuum can on 4 speed that I posted already.
Here is a 400 4bbl. auto distributor:
Ron
Re: Vacuum Advance Differences? [Re: RJS] #1741707
01/30/15 01:06 AM
01/30/15 01:06 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Unless there is something wrong with your distributor get a tag from Bill Rolick and call it a day.
Ron
Re: Vacuum Advance Differences? [Re: RJS] #1741708
01/30/15 01:13 AM
01/30/15 01:13 AM
NE
NE
That's a nice engine pic. But that distributor is a 1974. Are the internals(weights and springs)of a 1974 the same as a 1972?
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741709
01/30/15 01:22 AM
01/30/15 01:22 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
That's a nice engine pic. But that distributor is a 1974. Are the internals of a 1974 the same as a 1972?
He is right, that IS a beautiful view!
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741710
01/30/15 11:07 AM
01/30/15 11:07 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Are you worried about the two distributors performing the same? I'm not certain of the answer to your question but either way the car would perform better if you changed the springs.
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741711
01/30/15 11:07 AM
01/30/15 11:07 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
For the distributor to perform to spec, rather than just look correct, your odds are best if you can get hold one specifically for your '72 400 4 bbl auto. However, if you have access to a distributor tester, or are willing to spend some time testing on engine with a timing light, you can modify the internals to meet spec.
It will be hard to find the replacement springs by part number - although can try. Even more true for the top shaft-slot plate. So it comes down to tweaking what you have, taking parts from other applications or doner distributors and so forth. A standard, all mechanical vacuum advance will be not so hard as a pretty good range is still available new.
First thing to do is get a hold of a '72 shop book and write down the specs. Then look for all other applications with the same specs. A '72 parts book will reveal if the vacuum pod, springs etc were used for other applications that year. Then you can look at other years and if you post up, some of us can help by looking at other years.
In addition to the spring rate and advance slots (mechanical advance allowed), adjustments can be made to the initial spring force by turning the spring posts. The /6 folks know this, but everyone else seems to be unaware of it. On the secondary side this will change the point when the long loop engages.
Not many books on how dizzy's work. Some tech info here on the 'new' 1961 Chrysler built distributor
http://www.imperialclub.org/Repair/Lit/Master/136/index.htm
Re: Vacuum Advance Differences? [Re: Mattax] #1741712
02/01/15 09:24 PM
02/01/15 09:24 PM
NE
NE
Thanks for the responses. I do Not have a Factory Shop Manual or Parts Book. I did look at the auto parts store sites like Rockauto and autozone and found that they don't have a different part for a 4bbl or a 2 bbl and also don't differentiate between 4spd and auto. Anyone know how one of these re-mans are set internally?
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741713
02/02/15 02:00 AM
02/02/15 02:00 AM
I'd go ahead & get the one listed for your app (# on the arm) & adj it with the allen wrench to come in just under the pinging point (which can be anywhere in the slope as your eng/gas/elevation/driving style etc are different from the next guy with the exact same setup) if you want to get it spot on. bottom line NO pinging allowed under any circumstances, You stay fairly close to the line but never over it
Re: Vacuum Advance Differences? [Re: moparpoolman] #1741714
02/02/15 09:06 AM
02/02/15 09:06 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
please explain how this works:
