Fiberglass hood scoop mounting solution needed???
#174136
12/24/08 02:19 PM
12/24/08 02:19 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I have a nice AAR 67 B-Body hood scoop that I want to put on my 83 Cordoba...... It has the built in mounting studs and it looks like a quality piece. My issue is the doba hood is not completely flat. Towards the the very back of the hood (by the windshield), it has a lip and a slight rise up about 3/8". The rise starts about 2 inches from the back of the hood.
If I move the hood forward off the lip it would mount fine with no issues and be easy to do. Unfortunatley, the front part of the scoop overhangs the body lines on the hood so that will not work. The scoop must be mounted right to the back of the hood.
What is the best way to make the scoop fit?? Should I make a cardboard template that matches the amount of hood rise and then grind the scoop to match??? I don't see any other way so I need some help here.... Check out the pic and you will see what I mean. click to enlarge... thanks TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
