Re: Do I Need a Proportioning Valve?
[Re: CHRGR69]
#174119
12/26/08 01:42 PM
12/26/08 01:42 PM
Posts: 1,565 tennessee
pushbutton
tennessee
72 Cuda drums all around. Have a power booster with M/C laying around.
I thought the question was about a all drum set up
[Re: pushbutton]
#174120
12/26/08 03:11 PM
12/26/08 03:11 PM
RapidRobert
I believe it was. We got sidetracked a bit.
[Re: RapidRobert]
#174121
12/26/08 05:16 PM
12/26/08 05:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
True, we (me) got sidetracked, sorry.
[Re: farmington]
#174123
12/27/08 09:30 AM
12/27/08 09:30 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
The factory valve is just a distribution block. Period!!!! It has the valve inside but its only for the brake light in the dash.
I can only speak from an '73 model perspective, but in the '73 factory service manual, you are indeed correct---only for an A-body. All the other models show an actual proportion valve.
Thus in replumbing my brakes in my '73 dartsport when i did a manual brakes, aluminum 2 bolt cylinder and line lock, i removed the distributon block and used theline lock to split the fronts. The rear was feed directly off the M/C. Car had discs fronts and drums rear (10"). I never had a problem with the few panic stops i encountered, but the rears would slightly lock first. And lets face it, in my application with 3.5" front wheels with 165r15 tires, the fronts werent going to do a whole lot.
Just my personal experience in modifying and doing a little research in factory systems---your experience may vary.
Outcast Dodge guy.
