Pinion Shaft Speedi-Sleeve Size 741 8 3/4 #1741148
01/28/15 03:42 PM
01/28/15 03:42 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I want to replace the pinion seal on my 741. I suspect that the pinion shaft will have some grooving since the car had 130,000 miles on it prior to restoration. I want to install a Speedi-Sleeve on the pinion shaft while I have the pinion off.
From my searches it looks to me that I will need a 1.875" sleeve. Am I correct or do I need a different size for my application?
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Pinion Shaft Speedi-Sleeve Size 741 8 3/4 [Re: FJR doc] #1741149
01/28/15 04:29 PM
01/28/15 04:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's the correct one SKF Part # 99187
Re: Pinion Shaft Speedi-Sleeve Size 741 8 3/4 [Re: John_Kunkel] #1741150
01/28/15 04:30 PM
01/28/15 04:30 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Thanks John. I'll hit up the local NAPA store and pick one up for the weekend.
Kevin
Re: Pinion Shaft Speedi-Sleeve Size 741 8 3/4 [Re: FJR doc] #1741151
01/29/15 03:19 AM
01/29/15 03:19 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Re: Pinion Shaft Speedi-Sleeve Size 741 8 3/4 [Re: DoctorDiff] #1741152
01/29/15 10:39 AM
01/29/15 10:39 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Thanks for the info Doc!
Kevin
