Question about CalTracks... #1740705
01/27/15 09:41 PM
01/27/15 09:41 PM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
Have a 70 Charger.. when going CalTracks, does the front spring hanger need to be the short original one or should the front hanger be the longer SS spring hanger??? I have the longer front hangers and SS springs under the car right now....
Thanks!
/Tom
Re: Question about CalTracks... [Re: TomsCharger70] #1740706
01/27/15 09:48 PM
01/27/15 09:48 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Either one will work. Just tell Calvert which ones you are gonna use.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Question about CalTracks... [Re: steve660] #1740707
01/27/15 09:52 PM
01/27/15 09:52 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would use the longer one. Should work better.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Question about CalTracks... [Re: 1967dartgt] #1740708
01/27/15 10:38 PM
01/27/15 10:38 PM
Stockholm, Sweden
Stockholm, Sweden
Thanks for your posts!
Calvert should take some time and update the order info on their homepage. Like just a few written lines would go along way.. this you need to think about before placing your order, ex. if you have stock or SS spring hangers, then these are the part numbers... that way youll get the correct part/s and wont get all off..
Re: Question about CalTracks... [Re: TomsCharger70] #1740709
01/28/15 02:55 AM
01/28/15 02:55 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm pretty sure my calvert springs came with new spring eye mounting boxes.
Re: Question about CalTracks... [Re: TomsCharger70] #1740710
01/28/15 11:23 AM
01/28/15 11:23 AM
an8sec70cuda Offline
Why use the longer front hanger for the shorter SS springs? The shorter stock hanger and stock springs should work better...same reason the fast cars are going to the longer chevy leaf springs.
FWIW...I use stock length springs and stock hangers on my cuda. Been 1.320 sixty foot footbraking at 3800 lbs. on a 295-65 drag radial.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Question about CalTracks... [Re: an8sec70cuda] #1740711
01/28/15 11:35 AM
01/28/15 11:35 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I went w/ the 20" SS front segments because I simply swapped from SS springs to CalTracs using the same length springs. Although they've worked OK, I'm planning to switch back to the 22" front segments w/ some AR Engineering replacement front hangers. If I was swapping "from scratch", I'd definitely go w/ the longer springs, too.
Re: Question about CalTracks... [Re: TomsCharger70] #1740712
01/28/15 01:13 PM
01/28/15 01:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s where a phone call helps................ASSume nothing..........
Re: Question about CalTracks... [Re: Thumperdart] #1740713
01/28/15 04:41 PM
01/28/15 04:41 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am going a little different route on my project.
I am going to use a front segment from this kit (if they will sell it to me)...I don't want to have to take the springs out of the truck
http://www.srdparts.com/index.php?page=s...t&Itemid=1.
and I have to modify the existing truck spring plates to accept some mounts I took off a ladder bar kit, because their spring plates don't have the shock mounts I want and I am going to swap the spring plates from left to right so that I can mount the shocks in front of the axle rather than stock behind it. Then I will use the roller kit that I got to anchor the rear of the leafs. It will all make sense when I put it together
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Question about CalTracks... [Re: 1967dartgt] #1740714
01/28/15 08:59 PM
01/28/15 08:59 PM
Stockholm, Sweden
Stockholm, Sweden
How and what is the difference, if the spring length and spring preloadbar is shorter vs. longer?
Re: Question about CalTracks... [Re: TomsCharger70] #1740715
01/28/15 09:40 PM
01/28/15 09:40 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Mine did also !
Re: Question about CalTracks... [Re: TomsCharger70] #1740716
01/28/15 11:54 PM
01/28/15 11:54 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
When going to a longer front spring segment, in almost all cases, you move the Instant Center closer to the 100% anti-squat line, which, in almost all cases, is a good thing...
If you can't handle the truth, you're living a lie.......
Re: Question about CalTracks... [Re: Big Squeeze] #1740717
01/29/15 12:30 AM
01/29/15 12:30 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I went w/the 25" ft. segment but havn`t had a good track day to try em out and went 1.46 60 ft. and 6.20 @ 111+ in the summer heat before sliders and vertically mounting the rear shocks..............
Re: Question about CalTracks... [Re: Big Squeeze] #1740718
01/29/15 02:17 AM
01/29/15 02:17 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I should have been more clear as I meant use longer spring caltrac bar not mount. Sorry for the confusion.
Re: Question about CalTracks... [Re: 1967dartgt] #1740719
01/29/15 02:44 AM
01/29/15 02:44 AM
Stockholm, Sweden
Stockholm, Sweden
Ok, så 22" front segment and short front spring hangers
Thanks!
Re: Question about CalTracks... [Re: TomsCharger70] #1740720
01/29/15 11:09 AM
01/29/15 11:09 AM
Thanks!
Yes. The longer the front segment of the spring is, the better.
CHIP
Re: Question about CalTracks... [Re: an8sec70cuda] #1740721
01/29/15 12:12 PM
01/29/15 12:12 PM
Guitar Jones Offline
You should just call Calvert and talk to them. Their guys are very helpful and will help you pick what would work best for you and what you want to do.
Re: Question about CalTracks... [Re: Guitar Jones] #1740722
01/29/15 06:56 PM
01/29/15 06:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He's in SWEDEN , might be a little cost prohibitive to CALL???
Re: Question about CalTracks... [Re: JohnRR] #1740723
01/29/15 08:48 PM
01/29/15 08:48 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Then send a email, just contact them before you plunk down your hard earned money.
Re: Question about CalTracks... [Re: 1967dartgt] #1740724
01/29/15 10:21 PM
01/29/15 10:21 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Does any one use the slider on the rear instead of the hanger
