Re: Cuda hood scoop insert question
[Re: 5carguy]
#1740585
01/27/15 08:04 PM
01/27/15 08:04 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: 5carguy]
#1740587
01/28/15 04:20 AM
01/28/15 04:20 AM
Posts: 1,652 Calgary, Alberta Canada
m46rat
On the Cuda duel scoop hood there are black finned inserts that are held in place by two screws each side.Does anyone have a picture or know where I can buy these?What do they look like?Mine are MIA As always,TIA.
Just for your information, the grille insert that uses a set of small screws in the front as well as speed nuts in behind is for a 1972-1974 sport hood. 1970 and 1971 hoods do not have the two small screws inserted into the grille(the grille has no provision for them). The grilles themselves use the same part number for all years despite being very different for 1970-71 and 1972-74. The "scoops" that each grille is inserted into is also different because of this. The inside of the scoop has only two holes in it for 1970-71 and four holes for 1972-74.
[Re: 5carguy]
#1740588
01/28/15 09:42 AM
01/28/15 09:42 AM
Posts: 2,309 South, FL
cudaized
South, FL
