Cuda hood scoop insert question #1740584
01/27/15 07:53 PM
01/27/15 07:53 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
On the Cuda duel scoop hood there are black finned inserts that are held in place by two screws each side.Does anyone have a picture or know where I can buy these?What do they look like?Mine are MIA
As always,TIA.
Re: Cuda hood scoop insert question [Re: 5carguy] #1740585
01/27/15 08:04 PM
01/27/15 08:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
set on EBAY right now
Re: Cuda hood scoop insert question [Re: 5carguy] #1740586
01/27/15 08:05 PM
01/27/15 08:05 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I should have been more specific,I just need the screws.
Re: Cuda hood scoop insert question [Re: 5carguy] #1740587
01/28/15 04:20 AM
01/28/15 04:20 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
As always,TIA.
Just for your information, the grille insert that uses a set of small screws in the front as well as speed nuts in behind is for a 1972-1974 sport hood. 1970 and 1971 hoods do not have the two small screws inserted into the grille(the grille has no provision for them). The grilles themselves use the same part number for all years despite being very different for 1970-71 and 1972-74. The "scoops" that each grille is inserted into is also different because of this. The inside of the scoop has only two holes in it for 1970-71 and four holes for 1972-74.
Re: Cuda hood scoop insert question [Re: 5carguy] #1740588
01/28/15 09:42 AM
01/28/15 09:42 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
