Page 1 of 3 1 2 3
EFI #1740286
01/27/15 04:33 PM
01/27/15 04:33 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I am sure this will open a big discussion and that's good. my main point I would like answered is
will efi make my care faster and more consistent?
I understand that chassis has a lot to do with it as well but my car has always had the same 60 foot numbers more less from time to time. it doesn't swing very much.
so what will efi do for me??
thanks as always
Thank you
Kiddart
Re: EFI [Re: Kiddart] #1740287
01/27/15 05:04 PM
01/27/15 05:04 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yes.
The torque picks up across the entire RPM range.
I have been running FAST for 15 years
Re: EFI [Re: Kiddart] #1740288
01/27/15 05:13 PM
01/27/15 05:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
thanks as always
It should start and idle instantly.
Will it be faster? Maybe. Probably not much unless your carb is completely off the reservation.
Consistent? It should be if for no other reason than it will correct itself for weather. This assumes that you get the fuel and timing map dialed in.
Kevin
Re: EFI [Re: Twostick] #1740289
01/27/15 05:32 PM
01/27/15 05:32 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
technically you could be faster if you use things like anti spin built into some of the efi controllers, as well as getting your fuel and timing maps adjusted correctly. possibly freeing up some hp if your still running a mechanical fan and switching to computer controlled electric fans. you will most likely have a bigger throttle body than your carb so you may pick up some hp on the top end. also depending on the intake you choose, find one with the longest runners and convert that, like a tunnel ram.
so yeah you should be faster.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: EFI [Re: Twostick] #1740290
01/27/15 05:43 PM
01/27/15 05:43 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I almost hesitate getting into this - but - what the heck. I will try to attach a document I wrote years ago which discusses this topic in detail. I can’t attach it because it's a .doc file. Send me an email and I’ll forward it.
The quick answer is yes. You should not plan on running any faster because the maximum horsepower for a well-tuned carbureted motor will be about the same. You could eke out a bit more with EFI if you are willing to spend some serious time on the engine dyno adjusting the A/F ratio and timing cylinder by cylinder, but it’s usually not worth it. In pro-stock where 5 HP matters, sure, but not required in bracket racing.
Consistency should be better:
* With sequential port injection the manifold carries only air so you can get the A/F ratios equalized.
* Modern EFI systems can measure the atmospheric conditions and make adjustments in real time.
* Fuel variances are not often discussed, but it’s a factor. Methanol is better that gasoline for consistency. I won’t go any deeper than that here.
Many EFI racing users do not get into this level of detail, but if you spend the time you can reap subtle benefits. When I raced an alcohol motor I found a second benefit that I didn't really think about. Namely, it was simple to switch back to gasoline (switching to a gasoline program) and flush the fuel system while pulling the car in the trailer. This minor point made Methanol very tolerable. That, plus the ability to datalog each run was really a nice feature.
Re: EFI [Re: Jerry] #1740291
01/27/15 05:44 PM
01/27/15 05:44 PM
Canada
onig Offline
onig  Offline
Canada
Easier and quicker to tune once you understand EFI. It will also do a heck of a lot more than controlling your engine.
69 Dart
Re: EFI [Re: Mopar_Rich] #1740292
01/27/15 05:49 PM
01/27/15 05:49 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Maybe it was partially psychological, but I didn't win many bracket races until I committed to EFI. But all that fancy electronics can’t correct for a crappy driver who can’t cut a consistent light.
Re: EFI [Re: Mopar_Rich] #1740293
01/27/15 05:49 PM
01/27/15 05:49 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I'd be interested in the read, could you save as a pdf then attach?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: EFI [Re: OUTLAWD] #1740294
01/27/15 06:33 PM
01/27/15 06:33 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Probably not because there are pictures that would make the file too large. Send me an email and I'll respond.
Re: EFI [Re: Kiddart] #1740295
01/27/15 08:46 PM
01/27/15 08:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just started running EFI.. but I MIGHT have to make
a fuel table just for racing... in open loop its
trying to drive the A/F to stoichiometric all the time
and in a max power condition you want somewhere in
the 12.5 range... so just for racing I might have to
with a fuel table... it can be way more consistent
if you stay in open loop and let the O2 do the work..
I'll tell you come spring time which way I go on
the loop thing
Re: EFI [Re: MR_P_BODY] #1740296
01/27/15 08:55 PM
01/27/15 08:55 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
well I hope to be at the track the same time. hopefully I can pull the trigger on the system and we can learn it together
Thank you
Kiddart
Re: EFI [Re: Kiddart] #1740297
01/27/15 09:00 PM
01/27/15 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would be great... I'm gonna start out with the
O2 running the show then build a fuel table and see
which is faster
Re: EFI [Re: MR_P_BODY] #1740298
01/27/15 09:20 PM
01/27/15 09:20 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
the loop thing
It's closed loop that has the O2 sensor making corrections, not open loop. You could richen up your base fuel map to run richer like you want while racing and change to open loop when at the track so there is no O2 correction. Then you can tunr the Cloosed loop back on for driving around on the street. Or if you want, change the closed loop map to whatever AFR you want and have it run a richer mix during racing. I assume you EFI has a wide band O2 sensor? If not you won't be able to program for richer than stoic AFRs and you will have to do the first option.
Re: EFI [Re: blowndart] #1740299
01/27/15 10:04 PM
01/27/15 10:04 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Monte Smith and Edward Miller have made me decide to go EFI also on my R/T. Plan to start to the switch in March and have decided on the Holley Dominator EFI.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: EFI [Re: MR_P_BODY] #1740300
01/27/15 10:09 PM
01/27/15 10:09 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I just started running EFI.. but I MIGHT have to make a fuel table just for racing... in open loop its
the loop thing
You definitely want to stay in closed loop with a target A/F ratio in the mid 12s, but you also want a base fuel table that doesn't require that closed loop does all the work. You want the base fuel table to be close to ideal. This is because the closed loop correction is always "behind the curve" because it only sees what has already happened. You don't want to run a race engine lean at any time.
Re: EFI [Re: Mopar_Rich] #1740301
01/27/15 10:53 PM
01/27/15 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the loop thing
Thanks... sorta what I figured... do I have the
loop correct in that the O2 is working in open loop
(I can never remember that)
Re: EFI [Re: MR_P_BODY] #1740302
01/27/15 11:13 PM
01/27/15 11:13 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
No. The O2 sensor is used in closed loop and computes corrections to the base fuel table.
Re: EFI [Re: Mopar_Rich] #1740303
01/27/15 11:23 PM
01/27/15 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks... I dont know why I can never remember the loop
and I worked with injection for over 20 years.. but
I did the mechanical part.. nothing on the electrical part
Re: EFI [Re: MR_P_BODY] #1740304
01/28/15 12:38 AM
01/28/15 12:38 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'm pretty sure that in closed loop the ECU is trying to correct to the Air/Fuel ratio table not the fuel map.
If you have the correction set at 20% it will correct a lot more then at 5%
You use the wide band to dial in your base map. With the higher percentage. Then as you fine tune the fuel map by reading logs and overlaying them on the fuel table and adjusting the cells up or down. You back the percentage down so if the wide band goes out you don't burn up the motor.
Re: EFI [Re: FastmOp] #1740305
01/28/15 12:47 AM
01/28/15 12:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
For right now its in self learn mode..I just fired
it up before I left on vacation... its gonna be in
self learn mode when I get it out in the spring...
I'll be reading up on it till I have a better handle
on it.... as of now Monte just said keep it in the
self learn mode
Page 1 of 3 1 2 3
