EFI
#1740286
01/27/15 04:33 PM
01/27/15 04:33 PM
Posts: 1,552 Michigan
Kiddart
I am sure this will open a big discussion and that's good. my main point I would like answered is
will efi make my care faster and more consistent?
I understand that chassis has a lot to do with it as well but my car has always had the same 60 foot numbers more less from time to time. it doesn't swing very much.
so what will efi do for me??
thanks as always
Thank you Kiddart
Re: EFI
[Re: Kiddart]
#1740288
01/27/15 05:13 PM
01/27/15 05:13 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
thanks as always
It should start and idle instantly.
Will it be faster? Maybe. Probably not much unless your carb is completely off the reservation.
Consistent? It should be if for no other reason than it will correct itself for weather. This assumes that you get the fuel and timing map dialed in.
Kevin
Re: EFI
[Re: Jerry]
#1740291
01/27/15 05:44 PM
01/27/15 05:44 PM
Posts: 361 Canada
onig
Canada
Easier and quicker to tune once you understand EFI. It will also do a heck of a lot more than controlling your engine.
69 Dart
Re: EFI
[Re: Kiddart]
#1740295
01/27/15 08:46 PM
01/27/15 08:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just started running EFI.. but I MIGHT have to make a fuel table just for racing... in open loop its trying to drive the A/F to stoichiometric all the time and in a max power condition you want somewhere in the 12.5 range... so just for racing I might have to with a fuel table... it can be way more consistent if you stay in open loop and let the O2 do the work.. I'll tell you come spring time which way I go on the loop thing
Re: EFI
[Re: MR_P_BODY]
#1740296
01/27/15 08:55 PM
01/27/15 08:55 PM
Kiddart
well I hope to be at the track the same time. hopefully I can pull the trigger on the system and we can learn it together
Thank you Kiddart
Re: EFI
[Re: Kiddart]
#1740297
01/27/15 09:00 PM
01/27/15 09:00 PM
MR_P_BODY
That would be great... I'm gonna start out with the O2 running the show then build a fuel table and see which is faster
Re: EFI
[Re: MR_P_BODY]
#1740298
01/27/15 09:20 PM
01/27/15 09:20 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
It's closed loop that has the O2 sensor making corrections, not open loop. You could richen up your base fuel map to run richer like you want while racing and change to open loop when at the track so there is no O2 correction. Then you can tunr the Cloosed loop back on for driving around on the street. Or if you want, change the closed loop map to whatever AFR you want and have it run a richer mix during racing. I assume you EFI has a wide band O2 sensor? If not you won't be able to program for richer than stoic AFRs and you will have to do the first option.
Re: EFI
[Re: blowndart]
#1740299
01/27/15 10:04 PM
01/27/15 10:04 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Monte Smith and Edward Miller have made me decide to go EFI also on my R/T. Plan to start to the switch in March and have decided on the Holley Dominator EFI.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: EFI
[Re: MR_P_BODY]
#1740300
01/27/15 10:09 PM
01/27/15 10:09 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
You definitely want to stay in closed loop with a target A/F ratio in the mid 12s, but you also want a base fuel table that doesn't require that closed loop does all the work. You want the base fuel table to be close to ideal. This is because the closed loop correction is always "behind the curve" because it only sees what has already happened. You don't want to run a race engine lean at any time.
Re: EFI
[Re: Mopar_Rich]
#1740301
01/27/15 10:53 PM
01/27/15 10:53 PM
MR_P_BODY
Thanks... sorta what I figured... do I have the loop correct in that the O2 is working in open loop (I can never remember that)
Re: EFI
[Re: Mopar_Rich]
#1740303
01/27/15 11:23 PM
01/27/15 11:23 PM
MR_P_BODY
No. The O2 sensor is used in closed loop and computes corrections to the base fuel table.
Thanks... I dont know why I can never remember the loop and I worked with injection for over 20 years.. but I did the mechanical part.. nothing on the electrical part
Re: EFI
[Re: FastmOp]
#1740305
01/28/15 12:47 AM
01/28/15 12:47 AM
MR_P_BODY
I'm pretty sure that in closed loop the ECU is trying to correct to the Air/Fuel ratio table not the fuel map. If you have the correction set at 20% it will correct a lot more then at 5% You use the wide band to dial in your base map. With the higher percentage. Then as you fine tune the fuel map by reading logs and overlaying them on the fuel table and adjusting the cells up or down. You back the percentage down so if the wide band goes out you don't burn up the motor.
For right now its in self learn mode..I just fired it up before I left on vacation... its gonna be in self learn mode when I get it out in the spring... I'll be reading up on it till I have a better handle on it.... as of now Monte just said keep it in the self learn mode
