S60 or M60 ??
#1740126
01/27/15 12:34 PM
01/27/15 12:34 PM
Posts: 33 Denair,Ca
Armdropdart68
Denair,Ca
Which is better or which one do you recommend for a 1200hp drag car. The strange s60 or the moser m60
Re: S60 or M60 ??
[Re: Pntastar69]
#1740128
01/27/15 01:18 PM
01/27/15 01:18 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Google M60? Tanks and Guns
Google S60? Volvo
Might be a little more specific.
Strange or Moser versions of the Dana 60.
PM Dr. Diff. I'm using the S-60 from him and have had no issues.
Re: S60 or M60 ??
[Re: Pntastar69]
#1740129
01/27/15 01:19 PM
01/27/15 01:19 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
He's referring to a Dana60 rearend.
Edit: Tree'd
Re: S60 or M60 ??
[Re: Armdropdart68]
#1740131
01/27/15 01:37 PM
01/27/15 01:37 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I'd go w/ the S60 only b/c they have side adjusters for the carrier bearings...the M60 does not. I have an M60 in my cuda...been beating on it since 2003 w/ no trouble at all running in the 9s at 3800-3900 lbs.
Re: S60 or M60 ??
[Re: misfired]
#1740133
01/27/15 02:34 PM
01/27/15 02:34 PM
Posts: 345 Nebraska
451Cuda
Nebraska
What ever your preference is or which you can get cheaper. Also at that level I assume spool, girdle cover and 40spline...don't forget to price check against a 9"
And in that check specify the 9 with 12 bolt center, otherwise you're giving up efficiency to a Dana 60.
Re: S60 or M60 ??
[Re: 451Cuda]
#1740134
01/31/15 12:12 PM
01/31/15 12:12 PM
Posts: 1,629 pa
572charger
pa
m -60 since 2006 spool with street gear no problems
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: S60 or M60 ??
[Re: gsmopar]
#1740135
01/31/15 01:10 PM
01/31/15 01:10 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
My S60 is sitting at home. Can't wait to get out of the hospital and over it. I had bought a 1969 Dana 60, but by the time I switch over stuff to how I want it, I would have been spending a lot more on the old Dana than a brand new unit. It was marked from the favored as 3.54s but ended up being 410s. I went with 373's in the new unit. Just gotta detail my springs andn switch out the old setup.a new driveshaft will help with the changeover fro23 to18 spline transmission. The The Thanks Dr. Diff!!! Will be ordering a disc brake kit from him soon also.
Re: S60 or M60 ??
[Re: Quicktree]
#1740137
01/31/15 02:37 PM
01/31/15 02:37 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
ummmm strange 9"+ anything else a waste of money
Build us a comparable 9" street/strip rear end right here in this thread and show us how it's done. I'm all ears.
Re: S60 or M60 ??
[Re: Jeremiah]
#1740139
01/31/15 03:52 PM
01/31/15 03:52 PM
Quicktree
who cares the guy asked for a rear for a 1200hp drag car. and it can be done cheap for a street strip. just as easy as a dana.
Re: S60 or M60 ??
[Re: Quicktree]
#1740143
01/31/15 04:24 PM
01/31/15 04:24 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
probably so if you buy it new and built ready to install. if you do most of the work way less. i'll take a built 9" over a dana any day and will handle more power. you can't brace the tubes on a dana
You can buy empty S-60 housings too.
Re: S60 or M60 ??
[Re: justinp61]
#1740144
01/31/15 04:29 PM
01/31/15 04:29 PM
Quicktree
so, you can buy a junk yard 9" housing for $50 if you look around you may even find one with disc brakes. narrow it back brace you are ready. axles are a wash. you can find used 9" chunks all over the place cheap.
Re: S60 or M60 ??
[Re: Quicktree]
#1740145
01/31/15 04:49 PM
01/31/15 04:49 PM
justinp61
W. Kentucky
Bottom line, you run what you want and everyone else will too.
