Thanks Andyf, What is different between those two? The reason I'm asking is I swapped my stock disc spindles on my 70 challenger to a disc kit I bought from speedway motors. The spindle looked to be bigger diameter on the new kit compared to the stock 70 spindles. Next year I want to step up to a better 4 wheel disc brake kit but I think I'll need to order the fronts for a 73 or newer car. (if they are a bigger spindle design) So they will fit the new spindles I put on. But I'm not sure.
