challenger disc brake spindle question #173981
12/24/08 12:09 PM
12/24/08 12:09 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Hello, what is the difference between a 70 challenger and a 72 challenger disc brake spindle? Thanks
Re: challenger disc brake spindle question [Re: 440forPOWER] #173982
12/24/08 12:28 PM
12/24/08 12:28 PM
AndyF Offline
AndyF  Offline
No difference for 1970-72. The big difference came in 1973 when E body cars started to use the A body knuckles rather than borrowing the B body stuff.
Re: challenger disc brake spindle question [Re: AndyF] #173983
12/24/08 01:56 PM
12/24/08 01:56 PM
Lincoln NE
super gas
super gas
Lincoln NE
Thanks Andyf, What is different between those two? The reason I'm asking is I swapped my stock disc spindles on my 70 challenger to a disc kit I bought from speedway motors. The spindle looked to be bigger diameter on the new kit compared to the stock 70 spindles. Next year I want to step up to a better 4 wheel disc brake kit but I think I'll need to order the fronts for a 73 or newer car. (if they are a bigger spindle design) So they will fit the new spindles I put on. But I'm not sure.
Re: challenger disc brake spindle question [Re: 440forPOWER] #173984
12/24/08 02:03 PM
12/24/08 02:03 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
In 1973, the spindle diameter increased where the inner bearing and seal seat. Everything else is the same.
I make spacers that adapt the newer rotors to the early spindles.
Re: challenger disc brake spindle question [Re: DoctorDiff] #173985
12/24/08 02:10 PM
12/24/08 02:10 PM
Lincoln NE
super gas
super gas
Lincoln NE
Thanks Dr Diff, that what I figured. The sent out 73 and newer spindles with the kit. I just wanted to make sure. So I guess I'll need 73 and newer Wilwood kit. Thanks again
