Page 1 of 5 1 2 3 4 5
bigtimeauto / Alterkation users? #1739571
01/26/15 10:49 PM
01/26/15 10:49 PM
Chesterfield Twp. Mi.
John Burdine Offline OP
1. bigtimeauto, how much did you have Bill narrow the control arms to pull the front tires under the fender?
2. on my car, the top front shock mounts are reinforced/tied into the cage and will support coil over front suspension.
question is, would it be better to use my upper shock mounts and cut the mounts off the alterkation to allow for a longer shock/spring package, or leave it?
I thought I read the alterkation uses a short shock spring package and my car sits fairly low.
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739572
01/26/15 10:54 PM
01/26/15 10:54 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Unless you really need additional travel , I'd probably stick with the Alterktion mounts and shocks.
There ain't much there travel wise , but I haven't bottomed it yet with about a hundred street miles and assorted pounding so far.
Re: bigtimeauto / Alterkation users? [Re: tubtar] #1739573
01/26/15 11:20 PM
01/26/15 11:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO one of the weak links with the AlterK is the lack of shock travel. Now that I said that not all cars need a ton of shock travel depends on the power level. I also would want to cut the control arms down to pull the wheels in. One of the issues on the Hot Street car was ride height, but we could not get the front lower with the "stock" alterK stuff.
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739574
01/26/15 11:22 PM
01/26/15 11:22 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I believe my arms were shortened 1/2 and I use 2.25 bs rims. I do not have the short shock package.
Re: bigtimeauto / Alterkation users? [Re: 540dust] #1739575
01/26/15 11:24 PM
01/26/15 11:24 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Another..
Re: bigtimeauto / Alterkation users? [Re: 540dust] #1739576
01/26/15 11:59 PM
01/26/15 11:59 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I did mine myself I took 3/4" out of them and I use offset weld 2.0
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739577
01/27/15 12:06 AM
01/27/15 12:06 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739578
01/27/15 12:50 AM
01/27/15 12:50 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have ran across a couple good deals on the Alter K front end but have passed because of the width and the short shock travel. My car is a small block street/strip car and needs all the travel I can get to make it work. On high power cars that work well it may be the best thing since pockets on bibbed overalls.
Re: bigtimeauto / Alterkation users? [Re: justinp61] #1739579
01/27/15 01:24 AM
01/27/15 01:24 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The Valiant has Alterkation, I think it will work well
I used 2.25 back space wheels it tucked them in nice
Re: bigtimeauto / Alterkation users? [Re: bigdad] #1739580
01/27/15 01:31 AM
01/27/15 01:31 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: bigtimeauto / Alterkation users? [Re: bigdad] #1739581
01/27/15 01:40 AM
01/27/15 01:40 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
That Valiant is way freaking cool. It should launch well and certainly be one of a kind at the drags and most cruises.
Re: bigtimeauto / Alterkation users? [Re: dezduster] #1739582
01/27/15 01:56 AM
01/27/15 01:56 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Thanks, yeah its not a common car for sure
Hope to have it moving under its own power this summer
Re: bigtimeauto / Alterkation users? [Re: justinp61] #1739583
01/27/15 02:06 AM
01/27/15 02:06 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you need to start thinking out of the box. The alterkation is a great general platform to start with but like anything for a race car you need to make it work for you.
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739584
01/27/15 02:12 AM
01/27/15 02:12 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I can't quit understand what some folks talk about.
1- It makes ur front end 120lbs lighter
2- it gives you twice the room as a stock k frame
3- comes w Brakes that are 50x better then stock disc.
4- works absolutely perfect in 99.9 % of the cars where the owners use it.
5- rack and pinion steering,spindles are awesome.
It's a no brainer and one of the best upgrades out their...locally built,customer service is great Etc etc
Re: bigtimeauto / Alterkation users? [Re: fishy340] #1739585
01/27/15 03:14 AM
01/27/15 03:14 AM
anyone know if you can buy it without springs and shocks?
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739586
01/27/15 04:42 AM
01/27/15 04:42 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Hey John.
I will sell you mine for $10grand and throw
in the Demon and all my parts for free.
Re: bigtimeauto / Alterkation users? [Re: demon440] #1739587
01/27/15 05:06 AM
01/27/15 05:06 AM
Hey John.
how about $3000 and you can keep the car and parts.
so what your saying is, its not running yet. get bust man!
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739588
01/27/15 10:33 AM
01/27/15 10:33 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I tried to buy it less stuff, wasn't able to but, I didn't try really hard
It was complete with brakes, etc
$5350 shipped to me
Had I done a little more research, I'd bought one from Hemi Denny
same basic thing but, looks nicer
http://www.forabodiesonly.com/mopar/showthread.php?t=186472
And, I think its just a tad less $$ not much though
Re: bigtimeauto / Alterkation users? [Re: bigdad] #1739589
01/27/15 01:23 PM
01/27/15 01:23 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow, looks like a killer piece. Hi, Bob.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: bigtimeauto / Alterkation users? [Re: sunroofgtx] #1739590
01/27/15 01:32 PM
01/27/15 01:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks heavy to me...............and a 120 lbs. weight loss.........really?
