727 with 2.28 or 2.10 low gear #1738866
01/26/15 12:37 PM
01/26/15 12:37 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Is anyone running either of these? What is your experience from the switch? Looking into this to calm the Duster down at the launch a bit and hook more consistent.
Re: 727 with 2.28 or 2.10 low gear [Re: cl440] #1738867
01/26/15 12:59 PM
01/26/15 12:59 PM
gregsdart Offline
gregsdart  Offline
Just some math here. The 2.10 will take 14 percent of the launch torque away, the 2.28 a lot less. How expensive are those gear sets? I was thinking of going down from 4.56 rear gears to 4.10 at one time to help my deal.
Re: 727 with 2.28 or 2.10 low gear [Re: gregsdart] #1738868
01/26/15 01:38 PM
01/26/15 01:38 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
I put a set of 2.28s in Larry Boyd's car, and he love it. make a big difference on the launch.
www.facebook.com/CopeRacingTransmissions
Re: 727 with 2.28 or 2.10 low gear [Re: CRT] #1738869
01/26/15 01:52 PM
01/26/15 01:52 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Thats just a rear planet change right John? So it would be 2.28/1.45/1:1
7% just doesn't sound like a lot to me but it may work.
The 2.28 is a helical cut correct? How much HP will it handle (I know thats a tough one to answer LOL) Is it steel or Aluminum? I guess if its as strong as the stock 4 gear rear planet we have now it should work fine.
Re: 727 with 2.28 or 2.10 low gear [Re: cl440] #1738870
01/26/15 02:05 PM
01/26/15 02:05 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
ya its 2.28/1.45/1:1 helical cut Aluminum rear 4 pinion planet, sun gear, and ring gear can take, I would say if the car is 3500lbs and under, 1200HP anything over that, I would go straight cut gear set.
Re: 727 with 2.28 or 2.10 low gear [Re: CRT] #1738871
01/26/15 02:11 PM
01/26/15 02:11 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
We are 2850# with me in it and around 800 HP so sounds like it would work fine.
Re: 727 with 2.28 or 2.10 low gear [Re: cl440] #1738872
01/26/15 03:05 PM
01/26/15 03:05 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
oh ya
Re: 727 with 2.28 or 2.10 low gear [Re: CRT] #1738873
01/26/15 06:34 PM
01/26/15 06:34 PM
NC
440Jim Offline
440Jim  Offline
NC
I have the A&A 2.28 helical 1st gear in my 727; and it retains the 1.45 2nd gear ratio. This was around $700 when I bought it. It replaces the REAR planetary, and the sun gear (same sun shell). Since I bought the version with the Torrington thrust bearing, I also installed a new front planetary with the Torrington bearings. I picked the 5 pinion steel body front. The 2.10 setups I saw were way more expensive, but I like that ratio.
This did calm down the launch somewhat, along with the 4.10 rear gear and 31.8" tall slicks I run. At the end of 2014 (Oct) I put the new 540 CID engine in to replace the 511 CID. With the added torque of the 540 and the reduced nose weight of the aluminum block, the wheel stand came back. So I am adjusting for that some more. That day was 1000 ft DA, so it wasn't killer air and it wasn't bad air either. It went 9.02 at 147 mph and the sixty foots were 1.27x (3205 race weight).
I could have done without the 2.28 with the 511 and 4.10 gears, but with the new setup I am very happy I put the 2.28 1st gear set in the trans.
Re: 727 with 2.28 or 2.10 low gear [Re: 440Jim] #1738874
01/26/15 07:25 PM
01/26/15 07:25 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I would pay the money for the 2.10 if thats the way to go. I would rather pay that now then pay $800 for something that I may not be happy with.
On the flip side I dont want to kill it to much, but I would think it would be better than a 1.80 glide?
Some will say go with a Glide but I have all the good 727 parts (Duplicates of some) and (3) 8" 727 converters to play with and extra cases etc.....
If I was starting from scratch I would probably go Glide but I am not starting from scratch.
Re: 727 with 2.28 or 2.10 low gear [Re: cl440] #1738875
01/26/15 09:28 PM
01/26/15 09:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What rear gear? I run a 4.10. My car seems to work well at Milan on 10.5 tires with the standard gear set. 54% on the nose, 3340lbs. 60ft low 1.3x high 1.2x
Doug
Re: 727 with 2.28 or 2.10 low gear [Re: cl440] #1738876
01/26/15 10:12 PM
01/26/15 10:12 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
I have a 2.28 gear set in my trans that I will sell you. Have about 8 runs on it. after reading these post,I come to find out that it will not hold up to the power I am going to be making. I guest I was miss inform buy the trans guy. Let me know if you are interested.
Re: 727 with 2.28 or 2.10 low gear [Re: jkwedge540] #1738877
01/27/15 01:51 AM
01/27/15 01:51 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
Do they make a 210 first gear for a 904 ?
Re: 727 with 2.28 or 2.10 low gear [Re: meus31] #1738878
01/27/15 01:53 PM
01/27/15 01:53 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
4.10's with a 32-14 tire. 1.2X 60' times
Do you leave off a T brake Doug?
Re: 727 with 2.28 or 2.10 low gear [Re: cl440] #1738879
01/27/15 10:09 PM
01/27/15 10:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No, on the foot brake. Wheel base is shortened to 113". The car does have 36" ladder bars along with being nose heavy may be the calming factor. I also run the Front shocks stiff in extension. converter flashes 5600-5700. Been 1.32 w/ 10.5Wx31, 1.29 w/10.5x29.5 at Milan on regular bracket days.
Doug
Re: 727 with 2.28 or 2.10 low gear [Re: meus31] #1738880
01/28/15 03:49 AM
01/28/15 03:49 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Pro Trans may do, they are out in California somewhere.
Alan Jones
Re: 727 with 2.28 or 2.10 low gear [Re: LA360] #1738881
01/28/15 04:45 AM
01/28/15 04:45 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
http://www.protransracing.com/index.html Contact info for Protrans.
"Just a Bracket car dressed up like a streetcar"
