No fire, MSD or pickup, UPDATE
#1738469
01/25/15 08:29 PM
01/25/15 08:29 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Hi,
Went to move the RR today and it barely started. Now it will not fire at all.
I am 99% sure it is ignition related. What is a good way to troubleshoot whether it is the pickup or the MSD? Car cranks great, MSD is wired straight to the battery both power and ground, same as it has always been. Engine spins over great, has fuel. Get an occasional pop at best now. MSD is a 6AL, distributor is a Mopar Performance unit that has had the advance modified but nothing else.
I will do the pull plug test with plug grounded see if has a spark.
Best regards, Dave
Re: No fire, MSD or pickup
[Re: David_in_St_Croi]
#1738470
01/25/15 08:34 PM
01/25/15 08:34 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Most likely the MSD box. Look up their testing procedure on their website. MSD= might suddenly die!
unions....the folks who brought you the weekend!
#1738471
01/25/15 08:34 PM
01/25/15 08:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah pull the plug at the dist and jump it... if it sparks then its the pick up.. if it has advance in the dist you can pop the cap and turn the rotor also to see if it sparks then(after you pull the plug and jump it) and see if the reluctor gap is good(.008) EDIT If you turn the rotor.. make sure the coil lead is near the ground
[Re: MR_P_BODY]
#1738472
01/25/15 10:39 PM
01/25/15 10:39 PM
David_in_St_Croi
Thanks guys,
I will go to the MSD site and check out the testing procedures. Mr P Body, how do I trigger it to eliminate the pickup as the problem? The distributor still has advance in it so I can move the rotor. Actually, light just dawned on marblehead, I think. The idea is to move one of the reductor points past the pickup, then see if the coil wire triggers a spark. If it does not trigger the spark, how does that isolate the the pickup as opposed to the MSD? I apologize if I seem dense, spent all of today recovering from the work computer total failure, just barely saved the hard drive, so brain firing on even less cylinders than the RR.
Michelle, my incredibly smart and understanding wife, really liked the new acronym for MSD.
[Re: Jeremiah]
#1738474
01/25/15 11:02 PM
01/25/15 11:02 PM
David_in_St_Croi
Hi Jeremiah,
I will do that pickup test. DO you really mean I want to see a reading over 200 ohms, not under, for the pickup wires? I have a multimeter so that is no problem. To be absolutely clear, unplug the two wires coming from the distributor to the MSD. Then check across the terminals of the wire coming fr0m the distributor with the multimeter set to ohms. Does it matter where the reductor is? I would think not in this scenario as there is no current to create a magnetic field.
I think the airgap is correct and the rotor does move, at least it moved over time.
I don't know, it sounds like using a fuel line as a ground could give the most interesting results.......
Seriously, using the white wire, I assume have the ignition key on, then touch the white wire to ground while the big wire from the coil is about a 1/2 inch from ground should produce a big ass spark when the white wire is removed from ground, essentially doing what the points do.
Will most likely get to this tomorrow afternoon as already 2100 here so all this advice is incredibly helpful as I can go in with a full list of tests to use.
Best regards, Dave
[Re: 3ddart]
#1738476
01/26/15 11:31 AM
01/26/15 11:31 AM
David_in_St_Croi
Thanks for all the replies. I did the following diagnostics this morning:
1) put an ohmeter across the connector from the pickup, reading around 350 ohms.
2) I then took the wire off the cap and stuck a screwdriver up in it and laid it across the engine. I kept the wire from the distributor disconnected. I took the white wire and touched it to ground, then disconnected. Could hear the spark and seemed to be nice and blue.
3) Then, I did the same test only using a jumper across the connector from the MSD to the distributor. Similar result, consistent spark.
4) I then hooked the distributor back up. Left the coil wire set up as before. There was enough slack in the advance to move the reductor past the pickup. Nothing, or very occasionally a spark. I then loosened up the distributor and rotated the body back and forth. Similar result.
5) I did not check the gap but it looked about right. Not sure where the brass feeler gauge is currently located, entropy seems to have occurred on the bench.......
I am leaning toward the pickup but if anyone has some thoughts that will be great.
Best regards, Dave
#1738480
01/26/15 11:58 AM
01/26/15 11:58 AM
MR_P_BODY
Thanks MR. P Body,
Do those part numbers look to be the correct ones?
I dont know what the P/N is but the local parts store should have it or order it... its just a mopar dist
#1738482
01/26/15 01:05 PM
01/26/15 01:05 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
Did you try switching the polarity of the pickup wires?
Was suggested to me here by Bob George when I had a similar MSD no start problem. It worked! He said he sees it all the time. It's actually mentioned briefly in the MSD instructions - if the polarity is incorrect, it could cause the box to advance or retard the timing 40 degrees.
Worth a shot.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#1738483
01/26/15 01:09 PM
01/26/15 01:09 PM
MR_P_BODY
Worth a shot.
He has had a running car until it quit
