Engine sling lift points? #1738309
01/25/15 02:30 PM
01/25/15 02:30 PM
Torq37 Offline OP
Torq37  Offline OP
Anybody use these holes in the end of the head for attaching an engine sling? I’d prefer not the attach to the manifold/manifold bolts so was thinking to make a couple brackets that would attach to these holes and extend above the valve cover.
Re: Engine sling lift points? [Re: Torq37] #1738310
01/25/15 03:01 PM
01/25/15 03:01 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You can use them just fine, but just don't have too long of a bolt in there when installing on firewall end of engine. Some bolts won't have enough room to come out .
Re: Engine sling lift points? [Re: buildanother] #1738311
01/25/15 03:18 PM
01/25/15 03:18 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
I have used them before. Worked well
Re: Engine sling lift points? [Re: Torq37] #1738312
01/25/15 04:43 PM
01/25/15 04:43 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
All the time!!!!
Admiration For Multiple Carburetor Vehicles...
Re: Engine sling lift points? [Re: Stewpar] #1738313
01/25/15 05:26 PM
01/25/15 05:26 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Early 60 engines used to come with brackets bolted there.
Re: Engine sling lift points? [Re: Torq37] #1738314
01/25/15 05:54 PM
01/25/15 05:54 PM
AndyF Offline
AndyF  Offline
Those will work fine. I also make lifting tabs that bolt to the exhaust ports.
http://arengineering.com/products/lifting-tabs-big-block/
