School me on '03 Dodge Diesel trans dropping out of OD #1738090
01/25/15 03:26 AM
01/25/15 03:26 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
My first diesel with an auto since my '98 I bought new, and I am already having problems and wish I would have had more time to find a stick....I hate auto's..
So what now, change the two solenoids in it or is there something else I should be looking at?
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: Dragula] #1738091
01/25/15 05:12 PM
01/25/15 05:12 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
No codes? You checked fluid, right? They can be fluid sensitive sometimes.
Does it do it at a particular speed or is it random? Any other clues? Possibly a chafed wire somewhere. Know anyone with a DRB/Starscan? Might need to take it for a ride with the scanner and watch too see if something comes up.
When I was working, I replaced enough solenoids in transmissions but usually there was some sort of associated code. TCM is up to date with latest flash?
'71 Duster
'17 Ram 1500
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: RMCHRGR] #1738092
01/25/15 05:18 PM
01/25/15 05:18 PM
Dragula Offline OP
Dragula  Offline OP
I am thinking I might have melted a wire with a heat lamp trying to get it unfrozen a couple weeks ago, but the it only looks like the outer plastic on it melted. Not even sure what the wire does...And I can't remember when this started acting up, before or after.
Either way anything after 40mph, it drops out of fourth, if I am above 50 where the convertor locks, both drop out. No codes....
Did I mention I hate auto's
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: Dragula] #1738093
01/25/15 07:02 PM
01/25/15 07:02 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
My first thought is TPS, but I am not a diesel guy, maybe the 03 doesn't even have one ...
It takes gasoline to interest me.
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: VL21] #1738094
01/25/15 07:38 PM
01/25/15 07:38 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I was going to say that but you would probably have a code and likely other symptoms. Could be pending if it's intermittent but it sounds like the problem is present all the time.
Does it go into limp mode at all? Seems weird that you would have a symptom like that and no codes. Batteries/charging system good?
Might be a wheel speed or one of the shaft speed sensors. If any of those drop out, the trans may not know road or engine speed. Can't recall if you get codes for those, probably but you might not. You would have to look in the TCM or ABS systems with a scan tool to monitor them. Not sure if you can do it with a Modis, might need a DRB.
Again, see if you can find someone with a scan tool, it's going to be the most efficient way to narrow this down. It sounds like an electrical problem. Could also be the bus going down but that would likely lead back to a wiring issue. Might be a good time to figure out what that wire you melted is for... where was the wire?
BTW, if you go after one of those wheel speed sensors be aware that they tend to seize so proceed with care.
'71 Duster
'17 Ram 1500
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: Dragula] #1738095
01/25/15 08:00 PM
01/25/15 08:00 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Are you sure it's dropping out of OD or could it just be the converter unlocking? How much rpm increase? Read the link below.
http://www.kentsoil.com/dodgebug1.htm
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: John_Kunkel] #1738096
01/26/15 12:55 AM
01/26/15 12:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
reading through that link it pretty much refers to the VP equipped trucks from 98.5 to 2002. Lot of work prescribed there for something a/c duct foil tape will fix.
I HIGHLY doubt that RF noise is the cause of your woes, but also don't have many "been there/done that" scenarios relating to the DR trucks for "dropping out" of od or lockup. As mentioned, a good scan tool, and someone to monitor it properly is step 1 I'm thinking...
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: J_BODY] #1738097
01/26/15 02:45 PM
01/26/15 02:45 PM
dogdays Offline
dogdays  Offline
IMHO it's worth a shot. As it doesn't cost much and doesn't add any new parts I can't see a reason not do it.
Seems like an hour job for someone who knows his way around an engine compartment.
R.
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: dogdays] #1738098
01/26/15 11:44 PM
01/26/15 11:44 PM
Dragula Offline OP
Dragula  Offline OP
Found a place locally that can scan it...Tomorrow its going for a test drive with a scanner on it. Guy was leaning towards the temp sensor unlocking it....We will see.
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: Dragula] #1738099
01/28/15 11:54 AM
01/28/15 11:54 AM
Michigan Detroit area
Doc Schwarz Offline
Doc Schwarz  Offline
Another one is the governor at the rear of the trans.
Temp sensor, APPS, wire connection problem at the trans,
bad grounds, RF problem by the alt, brake light switch,
TCC switch, just to mention a few.
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: Doc Schwarz] #1738100
01/28/15 10:26 PM
01/28/15 10:26 PM
Dragula Offline OP
Dragula  Offline OP
It was a loose ground wire to the PCM...From the previous week when I had to change both batteries in 4 degree weather...
Re: School me on '03 Dodge Diesel trans dropping out of OD [Re: Dragula] #1738101
01/29/15 12:27 AM
01/29/15 12:27 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Glad you got it figured out and that you didn't have to throw parts at it.
'71 Duster
'17 Ram 1500
