challenger quarter glass seal install #1737708
01/24/15 03:34 PM
01/24/15 03:34 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
How is the seal held onto the glass frame ? weather-stripping adhesive ? In the photo are 2 tabs that are bent over. My new seals don't have a slot to accept these, just a small indentation. Should the tabs be trimmed off to only leave a short section left ? thanks
Re: challenger quarter glass seal install [Re: varunner] #1737709
01/25/15 10:15 PM
01/25/15 10:15 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What year? I think 70 is a one year only piece. My 73 just pushed on. The original ones pulled right off. The replacement were hard to push on.
Re: challenger quarter glass seal install [Re: burdar] #1737710
01/26/15 06:25 PM
01/26/15 06:25 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
1970. I ended up removing the tabs on the window and using weatherstrip adhesive. Seems to be fine. thanks
Re: challenger quarter glass seal install [Re: varunner] #1737711
01/27/15 03:24 AM
01/27/15 03:24 AM
California
1970mopar Offline
1970mopar  Offline
California
you have to poke the rubber seal at the indentations to create a hole for the metal tabs to go thru.
The metal tabs hold the seal at the base
