Holley Carburetor restoration #1737565
01/24/15 01:57 PM
01/24/15 01:57 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Where is the best place to get a Holley carburetor restored?
Re: Holley Carburetor restoration [Re: kpkube] #1737566
01/24/15 02:08 PM
01/24/15 02:08 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
An original equipment Holley or aftermarket?
Restored as in made to look like new, restored to be exactly perfect for concours restoration, or restored just to work like new?
Re: Holley Carburetor restoration [Re: Mattax] #1737567
01/24/15 02:52 PM
01/24/15 02:52 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Restored as in made to look like new. A member contacted me, and he does 100% concours
quality for $399. Looking around to get an idea who's service to go with.
Re: Holley Carburetor restoration [Re: kpkube] #1737568
01/24/15 02:58 PM
01/24/15 02:58 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Bill Overcash maxwgn62 did mine
the plating was the best i've seen and he helped
me out alot with incorrect parts. he know's his stuff..
Re: Holley Carburetor restoration [Re: flypaper] #1737569
01/24/15 03:04 PM
01/24/15 03:04 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Does he have a website?
Re: Holley Carburetor restoration [Re: kpkube] #1737570
01/24/15 03:26 PM
01/24/15 03:26 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Fair enough. Probably a step down from concours is http://www.carburetorusa.com/default.htm
They're in South Jersey near Philadelphia and as of a couple of years ago they did nice rebuild and I think refinishing on some OEM FSJ Motorcraft 2150s. See this thread at IFSJA forum for reference
http://www.ifsja.org/forums/vb/showthread.php?t=80335&page=2
Re: Holley Carburetor restoration [Re: kpkube] #1737571
01/24/15 04:18 PM
01/24/15 04:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This one not finished yet,PM me if interested.
Re: Holley Carburetor restoration [Re: kpkube] #1737572
01/24/15 04:32 PM
01/24/15 04:32 PM
Holley would be my choice They use to have a custom shop as well as factory rebuilt carbs.
Re: Holley Carburetor restoration [Re: Cab_Burge] #1737573
01/24/15 04:36 PM
01/24/15 04:36 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Re: Holley Carburetor restoration [Re: ademon] #1737574
01/24/15 05:11 PM
01/24/15 05:11 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks Ademon!
Here's one I recently did. BTW, I think Bill does awesome work and he has my full respect as a competitor.
Re: Holley Carburetor restoration [Re: ScottSmith_Harms] #1737575
01/24/15 05:32 PM
01/24/15 05:32 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Ironically: I thought Holley's own recoating was totally NOT the same as original?
Sheldon
Re: Holley Carburetor restoration [Re: RUNCHARGER] #1737576
01/24/15 05:43 PM
01/24/15 05:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Holleys current process does not produce the same results as it did in the 60's/70's, I have received several sets of "done" carbs from them to re-restore to make them more accurate. Here is one example from Holley "as received".
Re: Holley Carburetor restoration [Re: ScottSmith_Harms] #1737577
01/24/15 05:43 PM
01/24/15 05:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After I was finished with them
Re: Holley Carburetor restoration [Re: ScottSmith_Harms] #1737578
01/24/15 07:06 PM
01/24/15 07:06 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
From the "horses mouth",former head of custom shop, we use our dichromate solution as long as possible,the older it is the darker the finish it prodeces !
Re: Holley Carburetor restoration [Re: 62maxwgn] #1737579
01/24/15 07:12 PM
01/24/15 07:12 PM
RUNCHARGER Offline
RUNCHARGER  Offline
That's what I thought. Much better Scott.
Sheldon
Re: Holley Carburetor restoration [Re: ScottSmith_Harms] #1737580
01/24/15 07:31 PM
01/24/15 07:31 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Thanks, Those all look GREAT.
I couldn't find anything on the Holley website about their restorations.
Other people on some forums had issues with the Holley resto, and this was several years back. I do recall seeing Holleys resto site but this was sometime ago.
Just inquiring at the moment to see what options are out there.
Re: Holley Carburetor restoration [Re: kpkube] #1737581
01/24/15 07:43 PM
01/24/15 07:43 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You will also in some cases get incorrect parts,if you look at the 6 pk carbs Scott posted you will see that the set Holley did has the incorrect choke pull.
Re: Holley Carburetor restoration [Re: 62maxwgn] #1737582
01/24/15 10:34 PM
01/24/15 10:34 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
You can not go wrong with either member mentioned above. Both stand up guys.
Dan
Re: Holley Carburetor restoration [Re: ScottSmith_Harms] #1737583
01/25/15 01:40 AM
01/25/15 01:40 AM
Washington/Las Vegas
1971 Gran Coupe Offline
I visited with Scott Smith last spring for an hour or so, and I got to see his finished work in person. It is outstanding!! The pictures look great, but actually seeing the finished product up close is just amazing.
Re: Holley Carburetor restoration [Re: 1971 Gran Coupe] #1737584
01/25/15 11:29 AM
01/25/15 11:29 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I had a bud do two sets of Holley's for his AAR. Both were too dark, had incorrect parts and I had to fix one sets as the would not even run when he got them back.
