Re: A body 8.75 ?s
[Re: alpha727]
#173754
12/24/08 12:11 AM
12/24/08 12:11 AM
moparpollack
Lil Herman
Lil Herman
85086
The axel perches are .25 off on each side the springs can be squeezed to fit it wouldn't need shackles. The wheels would need to have a 5.25" or 5.5" backspace.
Re: A body 8.75 ?s
[Re: alpha727]
#173762
12/24/08 03:56 PM
12/24/08 03:56 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
Yukon A-body axles are actually 27.875" long. This does not provide enough spline engagement for early clutch sure-grips with 2 piece side gears. You need axles that are made to the correct length, or a NEW sure-grip with 1 piece side gears.
BTW, I stock new clutch sure-grips, correct length axles, powder-coated, bolt-in A-body 8 3/4" housings, drum and disc brakes and just about anything else you can think of for 8 3/4" and Dana 60 rears.
Re: A body 8.75 ?s
[Re: MoparTod]
#173764
12/24/08 07:11 PM
12/24/08 07:11 PM
DoctorDiff
Polson, MT
I sold at least as many Yukon A-body axles as ANY other Yukon dealer. Ever since I bought the first batch about 8 years ago, I have been trying to get the manufacturer to make the axles the correct length for use with ALL sure-grips.
I quit selling those axles a couple years ago because I got tired of asking everyone what type of sure-grip they are running. Most people don't even know without checking. I also did not like having to warranty stripped axles because the inner side gear only had 1/8" of spline engagement.
Judging by their latest website ad, Mancini Racing must have finally realized the problem with the axles, because the customer must now specify their diffential type when ordering.
The best part is, I now offer completely assembled, CUSTOM LENGTH, 30 AND 35 spline axle packages machined specifically for the application (by me) for about the same price as partially assembled off the shelf stuff.
