Page 1 of 3 1 2 3
V5* Body Side Molding picture request #1737455
01/24/15 10:18 AM
01/24/15 10:18 AM
Queensland, Australia
Hemiken Offline OP
Hemiken  Offline OP
Hi, has any one got any close up pictures of the body side moldings for a 1970 `Cuda/Gran Coupe/Barracuda they can share please. I would like to see the profile and also how it is trimmed off at each panel end.
Does anyone know if their is a molding available new too please.
Thanks,
Kenny.
Re: V5* Body Side Molding picture request [Re: Hemiken] #1737456
01/24/15 06:33 PM
01/24/15 06:33 PM
western australia
1cuda Offline
1cuda  Offline
western australia
https://board.moparts.org/ubbthreads/show...rue#Post8270906
this came up a while ago...i think the molding is white and black...NOT chrome and black for v5X.
all the best
frank...on my way to queensland for a week again (our carnarvon bananas are tastier)
Re: V5* Body Side Molding picture request [Re: 1cuda] #1737457
01/24/15 09:53 PM
01/24/15 09:53 PM
Hemiken Offline OP
Hemiken  Offline OP
Thanks for that Frank
But i was looking more for a close up of the ends and how they are cut, it seems that the very ends are not just a straight cut. But i have checked out that thread before buddy
Still looking if someone has these on their car they can share pictures of them please.
Re: V5* Body Side Molding picture request [Re: Hemiken] #1737458
01/24/15 09:57 PM
01/24/15 09:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& '70s are significantly different than '71s (I'll go look for some pics )
Re: V5* Body Side Molding picture request [Re: 6bblgt] #1737459
01/24/15 10:00 PM
01/24/15 10:00 PM
Hemiken Offline OP
Hemiken  Offline OP
Thanks Dan,
I knew the two were different. Thanks for having a look my friend.
Re: V5* Body Side Molding picture request [Re: Hemiken] #1737460
01/25/15 07:52 PM
01/25/15 07:52 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
This might help, took the pic at Carlisle last summer. My Cuda is a V5R car.
1971 BS23H1B
Re: V5* Body Side Molding picture request [Re: tx9cuda] #1737461
01/26/15 02:00 AM
01/26/15 02:00 AM
Hemiken Offline OP
Hemiken  Offline OP
WOW, that is awesome. Thanks for sharing that.
That is what i am looking for, some profile shots of the ends of the trim itself would be good too, and any more pictures of the trim on other 70 Barracuda/Gran Coupe/`Cuda please.
Re: V5* Body Side Molding picture request [Re: Hemiken] #1737462
01/26/15 09:36 AM
01/26/15 09:36 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
The ends of the mouldings are fairly crude and appear to have been cut using a heated wire or similar hot utensil.
I thought that I had some pics on file from one of the earlier threads a year or two ago, but apparently not, however, I can take some once we open the place up north in a couple of months.
There was some discussion about having them reproduced, and I'm willing to lend my NOS set as patterns.
Re: V5* Body Side Molding picture request [Re: YYZ] #1737463
01/26/15 09:40 AM
01/26/15 09:40 AM
Hemiken Offline OP
Hemiken  Offline OP
Thanks for your reply.
Interesting to hear how the ends may have been parted, it makes sense it was done that way. Are the mouldings very pliable, as in flexible. They look like they are not very forgiving in structural strength if not applied correctly.
What colour are the NOS ones you have please ?
Re: V5* Body Side Molding picture request [Re: Hemiken] #1737464
01/26/15 11:03 AM
01/26/15 11:03 AM
YYZ Offline
YYZ  Offline
It's hard to gauge as the set I have is quite old and not terribly pliable now. However, I don't think that they'd be any worse than an aftermarket body side moulding -- the consistency of the material has a definite stiffness. There is adhesive on the back, with the mandatory green tape to cover it as found on other Chrysler emblems and trim.
Cross-section is about 1cm x .5cm and rounded.
They are definitely an extrusion. I would think that if one had access to the right forming equipment, a die with the right profile would be very easy to make.
My NOS set is black.
Re: V5* Body Side Molding picture request [Re: YYZ] #1737465
01/26/15 03:27 PM
01/26/15 03:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If someone wants the challenge/cost of having these moldings made, the firm that could do a small custom run based on your specs/supplied sample would be PolyForm Inc in Oregon... www.plasticextrusion.com
IIRC they also have a plant in British Columbia
Re: V5* Body Side Molding picture request [Re: YYZ] #1737466
01/27/15 10:55 AM
01/27/15 10:55 AM
Hemiken Offline OP
Hemiken  Offline OP
Is that a guess at the size or the real size, they are only small if that is correct.
I totally hear what your saying about the brittleness with age, and how when new they would be more pliable, just as you say, pretty much the same flex as what a modern day moulding would be.
Re: V5* Body Side Molding picture request [Re: Hemiken] #1737467
01/28/15 10:08 AM
01/28/15 10:08 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Will these do Kenny?
1970 a
Re: V5* Body Side Molding picture request [Re: cudaized] #1737468
01/28/15 10:09 AM
01/28/15 10:09 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
b
Re: V5* Body Side Molding picture request [Re: cudaized] #1737469
01/28/15 10:10 AM
01/28/15 10:10 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
c
Re: V5* Body Side Molding picture request [Re: cudaized] #1737470
01/28/15 10:11 AM
01/28/15 10:11 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
d
Re: V5* Body Side Molding picture request [Re: cudaized] #1737471
01/28/15 10:12 AM
01/28/15 10:12 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
e
Re: V5* Body Side Molding picture request [Re: cudaized] #1737472
01/28/15 10:12 AM
01/28/15 10:12 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
f
Re: V5* Body Side Molding picture request [Re: cudaized] #1737473
01/28/15 10:13 AM
01/28/15 10:13 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
g
Re: V5* Body Side Molding picture request [Re: cudaized] #1737474
01/28/15 10:14 AM
01/28/15 10:14 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
h
Page 1 of 3 1 2 3
