rocker shaft shims, what are they good for? #173687
12/23/08 11:47 PM
12/23/08 11:47 PM
Anonymous OP
Anonymous OP
this is what can happen. i'll build a new stand and fix it, but i know my customer wishes he'd never heard of those things.
Re: rocker shaft shims, what are they good for? #173688
12/24/08 12:07 AM
12/24/08 12:07 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
why would shims cause that? oh , and by the way.....ouch!
Re: rocker shaft shims, what are they good for? [Re: dirtybee] #173689
12/24/08 12:36 AM
12/24/08 12:36 AM
Anonymous OP
Anonymous OP
the reason that can happen is that the saddle radius is .875". when you put a shim in the saddle, it reduces the width of the saddle by the thickness of the shim. when that happens, it tries to push the edges of the saddle apart when the rocker shaft bolts are tightended. in this case the stand/saddle just couldn't handle that much extra pressure.
i can tell this will be a lot of fun to fix.
Re: rocker shaft shims, what are they good for? [Re: dirtybee] #173690
12/24/08 12:38 AM
12/24/08 12:38 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
stock rocker arms? why was he using shims?
Re: rocker shaft shims, what are they good for? #173691
12/24/08 12:48 AM
12/24/08 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The shims I used some years back were thick on the bottom
.015 or .030 and thin on the walls, almost 0
Re: rocker shaft shims, what are they good for? [Re: sixpackgut] #173692
12/24/08 12:53 AM
12/24/08 12:53 AM
Anonymous OP
Anonymous OP
they aren't stock rockerarms. this is a pair of Zeeker heads with Zeeker/Dove rockers and the geometry is terrible. the customer used shims to try to correct it.
the rockers are too short and sit almost on the inner edge of the valve, they also didn't clear the 1.625 springs, even though they were already clearanced on the underside.
i'll correct the geometry for him without the use of conventional shims under the shafts and make a new stand to replace the damaged one.
i'm not sure if anyone cares, but maybe i'll post pictures of the completed repairs.
Re: rocker shaft shims, what are they good for? #173693
12/24/08 01:01 AM
12/24/08 01:01 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
well, i would be interested in seeing the repair and ....
the bill
Re: rocker shaft shims, what are they good for? [Re: sixpackgut] #173694
12/24/08 02:01 AM
12/24/08 02:01 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
they are actually VERY easy to fix. PM me for more info if interested.
Re: rocker shaft shims, what are they good for? [Re: prochargedhemi] #173695
12/24/08 04:00 AM
12/24/08 04:00 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i also would be interested in seeing the fix to this.thx.
Re: rocker shaft shims, what are they good for? [Re: dirtybee] #173696
12/24/08 05:37 AM
12/24/08 05:37 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
yikes---!
i think ive got .015 or so shims on mine , and with Dove rockers.
isnt that cast--how is that repairable ?
Re: rocker shaft shims, what are they good for? [Re: 493_DART] #173697
12/24/08 08:24 AM
12/24/08 08:24 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
what material were the shims?
Re: rocker shaft shims, what are they good for? [Re: CokeBottleKid] #173698
12/24/08 08:28 AM
12/24/08 08:28 AM
boscosis Offline
super street
boscosis  Offline
super street
I'd like to see the fix too. Remember that we had a set of HS rockers on Edelbrock heads with less than ideal geometry. We're going to run it the way it is but I'm wondering what it takes to mill off pedestals and make your own to correct it.
Re: rocker shaft shims, what are they good for? [Re: 493_DART] #173699
12/24/08 08:43 AM
12/24/08 08:43 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
yikes---!
Those heads are cast aluminum, and can be repaired by welding in a new piece and machining it back to spec.
I'd also love to see the repair
Karma has no menu. You get served what you deserve.
Re: rocker shaft shims, what are they good for? #173700
12/24/08 09:38 AM
12/24/08 09:38 AM
NC
440Jim Offline
440Jim  Offline
NC
Big Ouch!
1) Are you going to mill it off and use the bolt/stud to hold the fabricated stand in place?
2) What method are you going to use to correct the geometry the guy was trying to adjust with the shim under the shaft?
Re: rocker shaft shims, what are they good for? [Re: 493_DART] #173701
12/24/08 09:52 AM
12/24/08 09:52 AM
Anonymous OP
Anonymous OP
yikes---!
normally .015 or .030 shims won't hurt anything. these heads had considerably more than that.
even though the head is cast aluminum, it is can be welded. the castings are very rough and porous and that doesn't bode well for a good clean high strngth weld. porous cast aluminum can get brittle. fear not, we have the technology.
Re: rocker shaft shims, what are they good for? #173702
12/24/08 10:06 AM
12/24/08 10:06 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Dan,we see that alot with both iron and aluminum heads.Mostly when some one puts a washer under the shaft and trys to fit it by cranking down the bolt or stud nut.Generally we just machine off the stand and make a block with a through hole for the shaft and vertical hole for the hold down stud or bolt.That way we can offset the shaft hole up or down vertically or laterally to correct the geometry.On high lift,high pressure applications we add a locating pin to indicate the block to the head to keep the blocks in place since the holes for the hold downs need to be oversize for relocation and oiling.The block with 100% contact around the shaft and the large seat area(block to head)makes for a stronger attachment for the shaft and allows for unlimited correction capabilities.
Re: rocker shaft shims, what are they good for? #173703
12/24/08 10:10 AM
12/24/08 10:10 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The quality of the aluminum in the picture looks like crap & you confirmed that by saying they're Zeeker heads (Old)
I assume you're going to just machine the pedestals down & make a set of rocker blocks ala W2 like it should have had when Zeeker made them decades ago.
Re: rocker shaft shims, what are they good for? [Re: boscosis] #173704
12/24/08 10:38 AM
12/24/08 10:38 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I'm addressing that Edelbrock geometry issue with Harland Sharp. They work just fine, but they clearly can be better. A bazillion stes of them out there on Ebrocks and doesnt seem to affect them, but again, cleary can be better.
On the Zeekers, hopefully the customer will ante up for studs on that set up as well. If I re-call he was trying to use bolts to hold it all down too.
RIP Monte Smith
Re: rocker shaft shims, what are they good for? [Re: CompWedgeEngines] #173705
12/24/08 11:00 AM
12/24/08 11:00 AM
Anonymous OP
Anonymous OP
i've made rocker stands before for other heads. the only thing that comes into question on these heads is if there's enough material thickness to drill and tap for a longer stud after milling the old stand off.
Bob, i always put a dowel pin in to locate the stands also.
Re: rocker shaft shims, what are they good for? [Re: MR_P_BODY] #173706
12/24/08 11:01 AM
12/24/08 11:01 AM
sc
tjmarcus1 Online content
tjmarcus1  Online Content
sc
ditto! divorak has the correct ones that seem to work.
