Correct date code for fuel filter on AAR #1736915
01/23/15 03:25 PM
01/23/15 03:25 PM
Ashland City, Tennessee
Aar1064 Offline OP
Aar1064  Offline OP
Been searching posts for a while trying to figure this out and haven't gotten anywhere. Does anyone have an idea what date code I should be looking for?
Thanks moparts
Re: Correct date code for fuel filter on AAR [Re: Aar1064] #1736916
01/23/15 07:21 PM
01/23/15 07:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
One before the engine assembly date ...
Re: Correct date code for fuel filter on AAR [Re: JohnRR] #1736917
01/23/15 08:45 PM
01/23/15 08:45 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
At the rate you are going I'm figuring late 2016.
I couldn't resist.
Careful, your character's showing!
Re: Correct date code for fuel filter on AAR [Re: mopar346] #1736918
01/23/15 09:04 PM
01/23/15 09:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct, one that's before the engine assembly date, a couple weeks to a couple months would be generally acceptable
Re: Correct date code for fuel filter on AAR [Re: mopar346] #1736919
01/23/15 11:06 PM
01/23/15 11:06 PM
Aar1064 Offline OP
Aar1064  Offline OP
Watch it Slow Ride Dreamer. You can't rush perfection.
Re: Correct date code for fuel filter on AAR [Re: JohnRR] #1736920
01/23/15 11:13 PM
01/23/15 11:13 PM
Aar1064 Offline OP
Aar1064  Offline OP
Well since its a warranty block, I wonder what that means? Maybe an over the counter replacement with no date code.
Re: Correct date code for fuel filter on AAR [Re: Aar1064] #1736921
01/24/15 12:14 AM
01/24/15 12:14 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Most often the best description for a block without a VIN or assembly date is "Service Replacement" or "Parts" block. It would only be considered a "Warranty" block if it is accompanied by paperwork that ties it to a particular car getting a replacement block (or short block, etc.) as a replacement while under warranty. As far as your date coded fuel filter, get one dated in February 1970 or so and you should be good.
Re: Correct date code for fuel filter on AAR [Re: ScottSmith_Harms] #1736922
01/24/15 12:19 AM
01/24/15 12:19 AM
Aar1064 Offline OP
Aar1064  Offline OP
Awesome info here Scott. I didn't realize that. Thanks. I think you meant February 70.
Re: Correct date code for fuel filter on AAR [Re: Aar1064] #1736923
01/24/15 12:28 AM
01/24/15 12:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
yes, 70
Re: Correct date code for fuel filter on AAR [Re: ScottSmith_Harms] #1736924
01/24/15 12:34 AM
01/24/15 12:34 AM
mopar346 Offline
mopar346  Offline
I'd run a clear one for your break in and the first 50-100 miles and then switch to the proper filter, hoses and keystone clamps, I plan to do that any time now.
Re: Correct date code for fuel filter on AAR [Re: mopar346] #1736925
01/24/15 02:35 AM
01/24/15 02:35 AM
Aar1064 Offline OP
Aar1064  Offline OP
That makes sense. That'll keep me from buying two correct ones. Ya'll are so smart. Thanks Kevin.
Re: Correct date code for fuel filter on AAR [Re: Aar1064] #1736926
01/24/15 12:00 PM
01/24/15 12:00 PM
mopar346 Offline
mopar346  Offline
You can still buy 2 just send me one.:)
