Page 1 of 3 1 2 3
Hesitation ?? #1736726
01/23/15 03:12 AM
01/23/15 03:12 AM
pacific northwest
Stroker Scamp Online content OP
Stroker Scamp  Online Content OP
pacific northwest
Can an ignition issue cause the motor to stall or hesitate on a rapid full throttle whack?
Reason I ask is I have tried 3 different carbs on the same motor (stockish 340)same results.
The new carb is a 750 DP, been tuning it and its getting better but I think some thing else may be the culprit
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Hesitation ?? [Re: Stroker Scamp] #1736727
01/23/15 03:15 AM
01/23/15 03:15 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
could be as the cyl psi quickly rise, check to make sure your pickup to reluctor gap is at.008,
Re: Hesitation ?? [Re: Stroker Scamp] #1736728
01/23/15 04:58 AM
01/23/15 04:58 AM
Is the vacume advance hooked up? If so try disconnecting it and see if that helps or not
Re: Hesitation ?? [Re: Stroker Scamp] #1736729
01/23/15 12:07 PM
01/23/15 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You make sure that the timing is set right first...
then start on the carb.. make sure the pump arm and
pump start a shot when you move the throttle.. then
its how much
Re: Hesitation ?? [Re: Cab_Burge] #1736730
01/23/15 01:01 PM
01/23/15 01:01 PM
Az
Crizila Offline
Crizila  Offline
Az
- after 3 carbs, it's time to start looking at something else. Ignition timing would be a good next step. I have several distributors for sale - - - ok, just kidding.
Fastest 300
Re: Hesitation ?? [Re: Crizila] #1736731
01/23/15 02:25 PM
01/23/15 02:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you could put 10 carbs, if the pump shot is not right it will do the same thing. timing should be set and right before you adjust the carb.
Re: Hesitation ?? [Re: Stroker Scamp] #1736732
01/23/15 09:13 PM
01/23/15 09:13 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
I had the same problem with the 511 in my 69 Bee. I checked/tried everything and the hesitation was still always there. It was driving me nuts. Then I found a station near the house that sold 100% 93 octane gas. I started using that instead of the 10% ethanol crap and the hesitation went a way. May not solve your problem, but it is worth a try if you have access to 100% 92 or 93 octane.
Re: Hesitation ?? [Re: Quicktree] #1736733
01/23/15 09:53 PM
01/23/15 09:53 PM
Az
Crizila Offline
Crizila  Offline
Az
I went with the odds! 10 Carbs with focked up pump shots would be - rare.
Fastest 300
Re: Hesitation ?? [Re: Crizila] #1736734
01/24/15 05:45 AM
01/24/15 05:45 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sure you did, the chances of any carb being right the first time for any given combo unless it's specifically set up for it are slim I would think.
Re: Hesitation ?? [Re: Quicktree] #1736735
01/24/15 01:00 PM
01/24/15 01:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe in days of old AND some new where the brilliant whackos added more holes than swiss cheese and you musta missed the last thank you post. Bolted it on and raced NO adjustments...............Doesn`t happen everyday but when set up PROPERLY they can be real close. Too bad you didn`t send me yours so you could experience the same things.......
Re: Hesitation ?? [Re: Thumperdart] #1736736
01/24/15 01:21 PM
01/24/15 01:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
lol I don't have any problems with mine. it runs great and repeats
Re: Hesitation ?? [Re: Quicktree] #1736737
01/24/15 01:26 PM
01/24/15 01:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s what most "Bracket racers" say...............
Re: Hesitation ?? [Re: Stroker Scamp] #1736738
01/24/15 07:12 PM
01/24/15 07:12 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If your running a power valve with too low a number will do that. I like them 1.5 under in gear idle vacuum. Seems now days where carbs used to come with 6.5's or higher they are 4.5 helps take tunning for dummies with a cam out of equation.
Re: Hesitation ?? [Re: Dodgem] #1736739
01/24/15 07:33 PM
01/24/15 07:33 PM
pacific northwest
pacific northwest
Thanks for all the ideas, finally stopped raining so I will tweak it a bit and let you know.
Re: Hesitation ?? [Re: Dodgem] #1736740
01/24/15 08:01 PM
01/24/15 08:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NEGATIVE..........Doesn`t work that way unless you`re WAY into the transition on the primaries cos when the idle`s correct you can remove the jets w/no change. As far as p/v sizing, take a drive at a steady rate or slight load, look at that # then maybe drop down 1-2 for power enrichment..........
Re: Hesitation ?? [Re: Thumperdart] #1736741
01/24/15 08:07 PM
01/24/15 08:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
negative that method is for street driving, doesn't work well for a race car. it can and will cause a hesitation. the 1-1.5 HG below idle in gear works best for any race car I have seen. I usually don't run PV's don't need them
Re: Hesitation ?? [Re: Quicktree] #1736742
01/26/15 02:45 AM
01/26/15 02:45 AM
pacific northwest
pacific northwest
Well didn't have much time today, but took the Duster for a drive still have the full throttle whack hesitation and I have what sounds like a lean miss fire at 2500 RPM
pretty sure this is all not carb related.
Not sure where to look next except ignition
Re: Hesitation ?? [Re: Stroker Scamp] #1736743
01/26/15 08:26 AM
01/26/15 08:26 AM
Q
Quicktree Offline
Quicktree  Offline
Q
just for the heck of it change the squirters. go up one size and see if that helps any. I assume you have tried messing with the cams and have that part set up right? put a brown cam on them. you may very well have other problems but make 1 change at a time.
Re: Hesitation ?? [Re: Stroker Scamp] #1736744
01/26/15 01:27 PM
01/26/15 01:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Going through this on a guys car and the FIRST thing I suggested was a crank. comp. test and sure enuff he had several low cyls. for whatever reasons cos he hasn`t called back yet. I`d pull all of the plugs and see how they look then check plug wires etc.
Re: Hesitation ?? [Re: Thumperdart] #1736745
01/26/15 08:50 PM
01/26/15 08:50 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Hey Stroker, what is your base/initial timing at idle and how quick are you getting your total in......this is the first place to start.....Jesse
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Page 1 of 3 1 2 3
