RB Demon carb linkage #173671
12/23/08 10:44 PM
12/23/08 10:44 PM
St. Charles, MO
wingman Offline OP
Uncreative Title
wingman  Offline OP
Uncreative Title
St. Charles, MO
Does anyone have a good photo they could post?
I picked up the P.A.W. Demon Throttle Lever Bracket. It seems to fix my cable alignment issue (moves the attach point further outboard) but I am still not clear how the throttle cable/return spring/kickdown linkage should attach.
Thanks in advance for your help.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: RB Demon carb linkage [Re: wingman] #173672
12/24/08 08:33 AM
12/24/08 08:33 AM
NY usa
540challenger Offline
NY usa
I don't have a picture but i will get one when i get home for you.
I used the stock rod/screw on my challenger it goes into the top hole on the adapter you have.
on end on the inside is short for the throttle cable and the other is longer and you sild the kick down linkage on.
Re: RB Demon carb linkage [Re: 540challenger] #173673
12/24/08 08:36 AM
12/24/08 08:36 AM
NY usa
NY usa
Here is a link it is for a six barrel but you can see the black screw in the middle that is what you need.
http://cgi.ebay.com/ebaymotors/Throttle-...bayphotohosting
