Carb problem or something else #1736483
01/22/15 08:31 PM
01/22/15 08:31 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Hi,
Went to start the 440 and had to use starting fluid to get it to fire.
Looks like hardly any gas was coming to the carb. Then let it sit overnight and the fuel filter was empty again. Why would the gas drain back? Now it will take forever to get it started again.
Thank you Joe
Re: Carb problem or something else [Re: joedee] #1736484
01/22/15 08:35 PM
01/22/15 08:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bad fuel pump most likely. I would use gas to start rather than starter fluid. That stuff is hard on an engine.
Re: Carb problem or something else [Re: joedee] #1736485
01/22/15 09:36 PM
01/22/15 09:36 PM
recent problem? chronic problem? first thing I'd do is before I crank it, take off the air cleaner and look in the air horn & pull the throttle & see if you have several healthy squirts of gas from the nozzle
Re: Carb problem or something else [Re: RapidRobert] #1736486
01/23/15 01:54 PM
01/23/15 01:54 PM
dogdays Offline
dogdays  Offline
Gas drains back because there is a bad valve in the fuel pump. Replace the pump.
R.
Re: Carb problem or something else [Re: dogdays] #1736487
01/23/15 01:57 PM
01/23/15 01:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
R.
I suggest you look up the siphon effect then explain to us how gas in the carb bowl jumps the air gap above it to go back to the tank.
Don't be the exception.
Re: Carb problem or something else [Re: Supercuda] #1736488
01/24/15 12:20 AM
01/24/15 12:20 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Something else
Re: Carb problem or something else [Re: joedee] #1736489
01/24/15 07:57 AM
01/24/15 07:57 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
ThermoQuads do this.
These carbs are great when they are in good condition. Great mileage, great performance, but after years of operation, the Phenolic center warps and the seals at the base leak. Fuel doesn't just evaporate overnight, it slowly drips out and into the manifold. I have had this happen with several seasoned ThermoQuads.
All the Holley carbs I've had seem to retain fuel for several weeks. One of the reason that Holley type carbs start easier is because the accelerator pumps on Holleys are at the bottom of the fuel bowl. Even if the carb is down to 1/4" of fuel and the main jets are uncovered, the car can start. Carter based carbs like the AVS, AFB and ThermoQuad have a well for the accelerator pump off to the side. They are harder to start once the fuel level drops.
You'll need to respond with more info to get a more detailed suggestion.
Re: Carb problem or something else [Re: Supercuda] #1736490
01/24/15 03:14 PM
01/24/15 03:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
R.
If you read his original post you will see he said the fuel filter was empty.
Re: Carb problem or something else [Re: stumpy] #1736491
01/24/15 03:26 PM
01/24/15 03:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Still wouldn't stop the fuel in the carb bowl from starting the engine. Empty fuel filters are fairly common.
Re: Carb problem or something else [Re: Supercuda] #1736492
01/24/15 05:51 PM
01/24/15 05:51 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
Many times engine heat will evaporate the fuel in the carb. I would have the same problem if it weren't for the electric pump I'm using.
