Indy 572-13 heads #173635
12/23/08 08:35 PM
12/23/08 08:35 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Do these heads use the same spark plugs as the eddy heads , was suggested i use 3/4 reach plugs (ngk bcres) , these sit around 3/8" shy of the combustion chamber.
TIA.
Re: Indy 572-13 heads [Re: 602heavy] #173636
12/23/08 09:06 PM
12/23/08 09:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
yes
Re: Indy 572-13 heads [Re: 602heavy] #173637
12/23/08 09:44 PM
12/23/08 09:44 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Yes X2...you can go with an Autolite AR 3932, 3933, 3934 depending on the application....Champion C57CX-C63CX,
RIP Monte Smith
