When to change out break in oil? #1736321
01/22/15 01:45 PM
01/22/15 01:45 PM
Tampa
DusterDave Offline OP
Tampa
My new smallblock stroker has 8 dyno pulls and about 20 minutes of other run time. Haven't driven it yet. When should I replace the break in oil? I can't ask the builder because he's no longer with us.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: When to change out break in oil? [Re: DusterDave] #1736322
01/22/15 02:08 PM
01/22/15 02:08 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
IMO, now. It has done it's job.
Get the break-in stuff out of it and change to what ever oil you plan to use for running it hard.
Re: When to change out break in oil? [Re: PorkyPig] #1736323
01/22/15 02:26 PM
01/22/15 02:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
now
Re: When to change out break in oil? [Re: DusterDave] #1736324
01/22/15 03:07 PM
01/22/15 03:07 PM
I use the break in oil on the dyno to break in the cam and then make two or three mild pulls(2500 to 5500 RPM) and drain the oil and change the oil filter (I cut the oil filter open at the dyno and inspect it, if it looks normal, new motors make some metal, not a lot though ) and if everything looks good I continue to whup up(tune ) on the motor on the dyno the get max power and torque from it
Re: When to change out break in oil? [Re: DusterDave] #1736325
01/22/15 03:27 PM
01/22/15 03:27 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Dave I drove mine once before changing but I use the Lucas #10063-1 which can be used at every oil change if you want. I put a half bottle in at the oil change. It has the needed zinc.
