65 B Body front sway bar #1735855
01/21/15 07:56 PM
01/21/15 07:56 PM
Missoula, Montana
ChadP Offline OP
ChadP  Offline OP
Missoula, Montana
Want to install front sway bar on a 65 Dodge Coronet 500 with big block. Car did not have factory sway bar. Any photos of sway bar installed on a 65 B-Body would be very helpful. Considering PST bar kit.
'65 Coronet 500
Re: 65 B Body front sway bar [Re: ChadP] #1735856
01/21/15 08:28 PM
01/21/15 08:28 PM
Ontario Canada
3
300_dup5 Offline
300_dup5  Offline
Ontario Canada
What year k frame you have
Re: 65 B Body front sway bar [Re: 300_dup5] #1735857
01/21/15 08:29 PM
01/21/15 08:29 PM
Missoula, Montana
ChadP Offline OP
ChadP  Offline OP
Missoula, Montana
Stock K Frame - 1965 B-Body. Car was 361/auto, now 440/4 spd, but didn't change K-frame.
'65 Coronet 500
Re: 65 B Body front sway bar [Re: ChadP] #1735858
01/21/15 08:31 PM
01/21/15 08:31 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i used a firm-feel on my 65 coronet big block. big improvement.
Re: 65 B Body front sway bar [Re: ChadP] #1735859
01/23/15 01:50 AM
01/23/15 01:50 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
62 thru 66-1/2 used the same bar. The links hang the bar, and the "ends" clamp to the tension struts.
Rick
Re: 65 B Body front sway bar [Re: Rick_Ehrenberg] #1735860
01/23/15 05:05 AM
01/23/15 05:05 AM
Cab_Burge Online work
Cab_Burge  Online Work
I never seen a stock 1962 to 1965 B body have a sway bar from the factory,6 cyl, SB or BB Thats based on owning 6+ of them
Re: 65 B Body front sway bar [Re: Cab_Burge] #1735861
01/23/15 01:07 PM
01/23/15 01:07 PM
Marlboro, NY, USA
Marlboro, NY, USA
They were generally on wagons, cop caps, and hi-po big-blocks. Friend's '62 Polara 500 had one.
Rick
Re: 65 B Body front sway bar [Re: Rick_Ehrenberg] #1735862
01/23/15 01:25 PM
01/23/15 01:25 PM
Missoula, Montana
ChadP Offline OP
ChadP  Offline OP
Missoula, Montana
Thanks Rick - the bar I ordered from PST has not arrived yet...will be interesting to see if it's designed like the examples you sent. Appreciate the diagram and photo.
'65 Coronet 500
Re: 65 B Body front sway bar [Re: Cab_Burge] #1735863
01/23/15 02:50 PM
01/23/15 02:50 PM
AndyF Offline
AndyF  Offline
I have an original early b-body anti-sway bar hanging up in the shop. I'd never bother to put it on car since it is very wimpy. Besides, the bushings are all shot in it and there isn't an easy way to replace them.
Cleanest setup is to use an aftermarket bar for a late 60's b-body as well as the matching lower control arms. That gives you a really nice setup that looks stock and works well.
Another option is to swap K-frames to a later style but then you're into the hassle of moving the engine back.
I covered this topic in my B-body book complete with pictures.
Re: 65 B Body front sway bar [Re: AndyF] #1735864
01/24/15 02:55 PM
01/24/15 02:55 PM
Illinois
SGTFURY62 Offline
SGTFURY62  Offline
Illinois
I've used a 69 one in a few of my cars (62-65). Just drilled the mounting holes in k member lip for mid bar mounts and used hellwig control arm mounts. Worked wonderfully and on the cheap.
Re: 65 B Body front sway bar [Re: SGTFURY62] #1735865
01/24/15 09:49 PM
01/24/15 09:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
BINGO!
- Stu Harmon
Re: 65 B Body front sway bar [Re: Cab_Burge] #1735866
01/25/15 12:33 AM
01/25/15 12:33 AM
kansas
farmboy Offline
farmboy  Offline
kansas
This 64 had a sway bar, and the big front brakes, only one I have ever seen.
Re: 65 B Body front sway bar [Re: farmboy] #1735867
01/25/15 02:21 AM
01/25/15 02:21 AM
AndyF Offline
AndyF  Offline
I parted out a '65 Coronet a few years back and it had a front sway bar. I think it was a 318 car but it had a front bar and big drum brakes. Maybe a taxi option package or something?
Re: 65 B Body front sway bar [Re: AndyF] #1735868
01/25/15 06:29 PM
01/25/15 06:29 PM
New York
rarefish Offline
rarefish  Offline
New York
I pulled one off of a 64 Plymouth Savoy Police Car that I found in a junk yard several years ago. It is pretty hard to find the complete early B-Body factory sway bar set up due to all of the attaching parts that are needed.
Re: 65 B Body front sway bar [Re: Rick_Ehrenberg] #1735869
01/27/15 09:36 AM
01/27/15 09:36 AM
Melbourne
O
ossietim Offline
ossietim  Offline
O
Melbourne
Mines mounted differently to yours Rick...maybe they are different bars??
https://www.flickr.com/photos/mastersander/16378911742/in/photostream/lightbox/
