Page 1 of 4 1 2 3 4
Outdated tire questions? #1735528
01/21/15 02:01 PM
01/21/15 02:01 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
A few months ago one of the Mopar Magazines had an article regarding date codes and how to read them etc. Most of the shows I attend, the majority of the guys are running Goodyear Eagle GT II's, Goodyear Nascar, Eagle II's with the eagle head logo,and even the Goodyear nascar with the yellow letters. I'm sure most of these are outdated 5-10 years ago and we are limited to the BFG or Cooper Cobra in a 14 or 15" tire. Are you guys relying on the mileage on the tires instead of the age and is this safe?
Re: Outdated tire questions? [Re: Airgrabber] #1735529
01/21/15 02:16 PM
01/21/15 02:16 PM
dogdays Offline
dogdays  Offline
You may be mistaking show cars, trailer queens by another name, for cars that get driven regularly.
Even if they drive them (I doubt it) they swap tires for something modern when they hit the streets.
I regularly run tires to death and have had at least five cases of belts coming off at speed. All of these tires were older than the hills. I'm lucky I drive on straight lonely roads, well except the mountains.
We had a complete tread come off an old Michelin on the Interstate and the car instantly became a handful to drive. Front wheel drive, rear tire scalped. I wouldn't have guessed it would be so dangerous on the rear, but it was.
So use old tires at your own risk. Let someone else put the last few miles on them. Or do as I do, suffer through the episodes and endure the body damage occurring when the tread whips the fender to shreds.
R.
Re: Outdated tire questions? [Re: dogdays] #1735530
01/21/15 02:18 PM
01/21/15 02:18 PM
Andrewh Online content
Andrewh  Online Content
I maybe put 2000 miles a year on my car. at the rate I burn out tires on my DD, at around 20k miles, that is still 10 years of driving on a set before they would need to be replaced due to mileage.
generally, I make sure they aren't dry rotting, and replace them around they 6 to 8 year mark regardless of tread.
Re: Outdated tire questions? [Re: Airgrabber] #1735531
01/21/15 03:44 PM
01/21/15 03:44 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
"A few months ago one of the Mopar Magazines had an article regarding date codes and how to read them etc."
Do you remember which magazine? I must have missed the article. Tires on my Barracuda were on it when I purchased in 2004. Mostly garage miles.
Re: Outdated tire questions? [Re: Airgrabber] #1735532
01/21/15 05:28 PM
01/21/15 05:28 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Mileage.
If I changed tires on the cars by date, I would have more sets of tires than oil changes.
I've got BF's that have to be 20 years old now and I still run them up 85mph. They have maybe 1500 miles on them at the most.
Mo' Farts
Moderated by "tbagger".
Re: Outdated tire questions? [Re: Vert] #1735533
01/21/15 07:29 PM
01/21/15 07:29 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Mopar Action, Dec 2014, page 76
Re: Outdated tire questions? [Re: Grizzly] #1735534
01/21/15 07:37 PM
01/21/15 07:37 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Mileage.
Wear for me. Tires on the Charger are probably 12-13 yrs. old and still look good. Keep the air pressure checked and look them over at least once a month for cracks or bulges. Have about 20k on them.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Outdated tire questions? [Re: I_bleed_MOPAR] #1735535
01/21/15 07:57 PM
01/21/15 07:57 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My buddy had some mint looking 15yo tires on his car maybe a few thousand miles on them tops. Rear DS came apart at about 60mph on the expressway totaling the whole quarter panel . They also go bad on the inside and separate from the cords.
Re: Outdated tire questions? [Re: ademon] #1735536
01/21/15 09:45 PM
01/21/15 09:45 PM
dogdays Offline
dogdays  Offline
Three of my old tires that came apart were BFGs, the other two were Michelins. All were old enough to be in high school.
R.
Re: Outdated tire questions? [Re: Airgrabber] #1735537
01/21/15 10:06 PM
01/21/15 10:06 PM
Worcester, Mass
68goldfish Offline
68goldfish  Offline
Worcester, Mass
Here is one for ya! Massachusetts is considering failing you for a inspection sticker if your tires are ten years old. Right now, both of my daily driven cars have tires that are that old. These tires still have plenty of tread to go.
Re: Outdated tire questions? [Re: Airgrabber] #1735538
01/21/15 10:17 PM
01/21/15 10:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We use a lot of used tires on our stuff and I see a lot more failures on cheap import tires than I have ever seen on aged tires. Since matching doesn't matter as much on my trailers, I usually buy old spares at the pick-a-part yards for them. Full tread tires that haven't seen much sun and are often 10, 12, 15 years old or older. I don't have any more problems out of 15+ year old tires than I do out of 3 or 4 year old tires.
But on the newer cheap import tires, they often bust cords or throw their treads while still having 1/2 tread or so on our cars. Just plain poor construction.
So in my experience, the original construction of the tire is far, far more important than the age of the tire.
P.S. The number of tires that I mount that are not round is a real shocker. Sounds weird, but is true. Another example of poor construction.
Master, again and still
Re: Outdated tire questions? [Re: 68goldfish] #1735539
01/21/15 10:21 PM
01/21/15 10:21 PM
france
jose jones Offline
jose jones  Offline
france
You guys are playing roulette with your life and your prized Mopar's running tires over 4 years old I had a set on a B-Body that were 10 years old with all their tread, On the way to a Mopar show in Phoenix the driver side front BFG threw a chunk of tread off the tire about the size of a softball and about destroyed the front fender. NEVER AGAIN will I run old tires on anything.Don't gamble with your life on old tires
Re: Outdated tire questions? [Re: I_bleed_MOPAR] #1735540
01/21/15 10:52 PM
01/21/15 10:52 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Mileage.
Tim
Same here, Tim. I bought the tires for my Charger in June 2003 and have less than 10,000 miles on them. The rears have about 50% remaining, the fronts are at about 70%. They still look great because when the car isn't driven, it sits inside my shop with little sunlight inside. Last year I wanted to get the tires REbalanced and the "America's Tire" store wouldn't do it since the tires are more than 10 years old.
Lawsuits and greedy plaintiffs really screw over people.
Re: Outdated tire questions? [Re: jose jones] #1735541
01/21/15 10:56 PM
01/21/15 10:56 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Age, no more than five years for me. As the tire ages, even if stored inside, they dry out and get hard. Dry hard tires lose grip and don't handle good. I can feel the difference every time I replace the tires. I average about 2000 miles a year on the Bee.
Re: Outdated tire questions? [Re: Dabee] #1735542
01/21/15 11:18 PM
01/21/15 11:18 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Running old tires is like not believing in the after life - what if you're wrong!
No harm in replacing tires prematurely or believing in the after life even if you're wrong.
Time all the way for anything I care about, I cheat a little on the rear tires of the Charger cause the quarters are fubared anyway, but the fronts are new.
Careful, your character's showing!
Re: Outdated tire questions? [Re: mopar346] #1735543
01/22/15 03:08 AM
01/22/15 03:08 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Old tire blow out, just sitting in the driveway. Hadnt driven it that day.
(95 F250)
Re: Outdated tire questions? [Re: nomore65BelvJim] #1735544
01/22/15 03:10 AM
01/22/15 03:10 AM
Sounded like a 12 gauge going off.
Photo date: 6-17-2013
Re: Outdated tire questions? [Re: jose jones] #1735545
01/22/15 07:15 AM
01/22/15 07:15 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
HAH!!!!
I'm also playing with my life eating fast food and cheap supermarket meat and dairy. Why? because i'm not rich enough to own my own private farm, and farmers, that grow my own true organic meat and grain, to be prepared into daily meals by my own personal chef.
Must be nice to be rich!
Four years... hahahahahahahahahahaha.....
I think in my 25 years ov driving (bloody goddamn fast) i've owned ONE set ov tires that were under 4 years old. ONE. My POS Charger was even nice enough to break the K-member and scrub the fronts from brand blue-lettered-new to right down to the cords in 200 miles too... so yeah, owned a PAIR ov newer tires, and another for about 8 days.
Most ov my tires are anywhere from 10 to 20 years old. No helping that. I'd rather have some nice 15 year old BFG's on there than some brand new Coopers... or some 15 year old 295/50/15's than some brand new 235/70/15's.
Never had a problem... and i see more illegal speed on public roads than you (plural). Bet on that.
New tires are a luxury. The girlfriend brought brand new BFG G-Force KDW2's for her Mustang GT... damn that was nice...
Re: Outdated tire questions? [Re: Airgrabber] #1735546
01/22/15 02:31 PM
01/22/15 02:31 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
The only tires I have personally had that failed, came apart or broke cords, have ALL been BFG T/As.
Some bought new, some on the car when purchased.
I see BFG mentioned in this post also ...
Had a balance problem with one from new, at mounting, wouldn't balance it was so far out.
I still like the looks, but the quality? I think it is questionable.
It takes gasoline to interest me.
Re: Outdated tire questions? [Re: VL21] #1735547
01/22/15 02:44 PM
01/22/15 02:44 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
My hope is now that Michelin owns BF that the quality will be better.
The three sets I have now seem to be good.
But, in the past I've had two sets that didn't work out. Seperated 4 of them by running the car above the speed rating for 45 minutes, so, my fault. But, the other set, from brand-new they could not balance them and one of the back ones seperated. Wound up pulling them all off and put Generals on. I was really impressed with the Generals after going the rounds with BF.
Mo' Farts
Page 1 of 4 1 2 3 4
