11x3 rear brake drums on A12? #1735093
01/20/15 09:35 PM
01/20/15 09:35 PM
Connecticut
5126brl No more Offline OP
Connecticut
Looking for a new set of rear drums, For 1969 A12
Can not seem to find a listing for 11x3's
Any brand better than others? Thanks
Re: 11x3 rear brake drums? Who sells them [Re: 5126brl No more] #1735094
01/20/15 11:01 PM
01/20/15 11:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Why do you want C-body drums on your A12? 1969 B-bodies have 11 X 2.5 rear brakes.
Re: 11x3 rear brake drums? Who sells them [Re: NANKET] #1735095
01/20/15 11:20 PM
01/20/15 11:20 PM
Connecticut
Connecticut
Was not sure what 11x3's came on. I have seen a few people say that A12's had 11x3 rear and front.
Re: 11x3 rear brake drums? Who sells them [Re: 5126brl No more] #1735096
01/20/15 11:21 PM
01/20/15 11:21 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
My local Autozone shows them Duralast / Brake Drum - Rear
Part Number: 8860 $58 ea.
These are the right ones not 11x3
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 11x3 rear brake drums? Who sells them [Re: HemiRick] #1735097
01/20/15 11:28 PM
01/20/15 11:28 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Take care,
Rick
Re: 11x3 rear brake drums? Who sells them [Re: HemiRick] #1735098
01/20/15 11:34 PM
01/20/15 11:34 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
11x3 rears came on Imperials according to the FPM.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 11x3 rear brake drums? Who sells them [Re: HemiRick] #1735099
01/20/15 11:43 PM
01/20/15 11:43 PM
Connecticut
Connecticut
thanks guys
will need to look into this more.
Just pulled out my 1969 master dealer part listing book, last updates jan, 1971.
Shows 11x3 for dodge and Plymouth with heavy duty pkg? Also list belvedere and cornet with 11x3 front and rear with police pkg.
When I measured them today drums are 3" and shoes showed 2 7/8 wide. In book it shows a 2 3/4 rear shoe.
Re: 11x3 rear brake drums? Who sells them [Re: 5126brl No more] #1735100
01/21/15 12:19 AM
01/21/15 12:19 AM
Connecticut
Connecticut
looking at A12 option 1969,
From Galen. when car was decoded.
includes
B31 HD 11" brakes Front rear, Manual adj.
(B+C bodies) 1969 -1970
No width listed....
Re: 11x3 rear brake drums? [Re: NANKET] #1735101
01/21/15 06:40 PM
01/21/15 06:40 PM
Connecticut
Connecticut
So shoes are 2 7/8 wide
drums have a part number 36418 also mwyb5 c21.
Found out they are 11x3 from factory on rear.
Re: 11x3 rear brake drums? [Re: 5126brl No more] #1735102
01/21/15 11:03 PM
01/21/15 11:03 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
For an A12 car, rear drums should be 11x2.5....fronts are 11x3.
Re: 11x3 rear brake drums? [Re: LYNCHROAD69.5] #1735103
01/21/15 11:21 PM
01/21/15 11:21 PM
Connecticut
Connecticut
I am still looking into this and have found pics of a unrestored A12 with 11x3 on rear, car has 40k mileage and clip still holding rear drum on axle. Hope to hear from some other owners to see what theirs have. His and mine have same cast number on drums.
Found this on broadcast sheet codes
B28 is 11 x 2.5 brakes
B31 is HD Rear drums..
So is that standard on A12 or a One Of...
Re: 11x3 rear brake drums? [Re: 5126brl No more] #1735104
01/23/15 12:20 AM
01/23/15 12:20 AM
Massachusetts
Massachusetts
For ALL A12's, B31 will be located on line 5 of the broadcast sheet. This decodes as "HD 11" drums, manual adjustment". If the car has 11x3 drums on the rear now, more than likely they are not original factory installed...however, never say never...but unlikely.
Re: 11x3 rear brake drums? [Re: LYNCHROAD69.5] #1735105
01/23/15 12:00 PM
01/23/15 12:00 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Have you decoded the diff to see if it came with the car?
1969 Hemi Roadrunner 2nd owner
Re: 11x3 rear brake drums on A12? [Re: 69hemibeep] #1735106
01/23/15 12:09 PM
01/23/15 12:09 PM
Connecticut
Connecticut
Yes I did years ago. Factory Rear still in car.
I have spoken to two other A12 owners I know in the last few days and both have 11x3 rear.
One is a VERY low mileage car,
Other has been in family since new.
Also heard that they built the first run of A12's with 11x2.5 then later builds had the 11x3's.?
I found the drums and shoes I needed.
After looking online have found people with R/T's having 11x3 rears also.
I hope more owners chime in with what they have on their cars VS what we read they came with.
Re: 11x3 rear brake drums on A12? [Re: 5126brl No more] #1735107
01/23/15 02:09 PM
01/23/15 02:09 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
My '69 A12 Bee had the typical finned 11x2.5 rear drums and 11x3 up front.
Re: 11x3 rear brake drums? [Re: LYNCHROAD69.5] #1735108
01/23/15 11:24 PM
01/23/15 11:24 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Yes B31 is on the broadcast sheet but on line 6 under brakes. Member Lynchroad has all the specs on his post that seem to be on both my A12s Runners, manual brakes. I believe the drums are also finned.
1971 HEMI E BODY REGISTRY
Re: 11x3 rear brake drums on A12? [Re: 70440+6bbl] #1735109
01/24/15 11:18 AM
01/24/15 11:18 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Ditto. My A12 car is a July 1969 build date with original date coded DANA.
If you have pictures of your set up, please post.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 11x3 rear brake drums on A12? [Re: 5126brl No more] #2083101
05/30/16 10:45 PM
05/30/16 10:45 PM
NY
JPO Offline
JPO  Offline
NY
I was searching the web for info regarding my 69 Charger RT's rear brake drums and it lead me to this thread. The car is currently in storage and I am getting parts at this point. I'd like to redo the brakes. Although I don't have easy access to the car I was able to have them email me the attached picture. The drums have a 3641x number on them. The last letter is blurred but is likely an 8, (or maybe a 0 or 6). Doesn't that number mean this car has 11x3 rear brakes? If yes where can I get brake shoes etc as they seem really hard to find.
If I decide to put the correct setup on it instead, I assume that would be 11x2.5 right? since the car has drums all around and is an RT. Does anyone sell a complete 11x2.5 setup to just bolt on and be done? Are there any other concerns I should have if I switch back being what's on there now? Thanks and any advice will be appreciated.
Re: 11x3 rear brake drums on A12? [Re: 5126brl No more] #2083379
05/31/16 01:49 PM
05/31/16 01:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think someone changed the brakes from 11x2.5 to 11x3 as it would require a backing plate change also. Rebuild what is on the car.
What is the build date of the car ?
Re: 11x3 rear brake drums on A12? [Re: JohnRR] #2083409
05/31/16 02:50 PM
05/31/16 02:50 PM
NY
JPO Offline
JPO  Offline
NY
I will get back to you with the exact build date. The car is a late '68 build. I have general car knowledge .. but am limited when it comes to restoring a car 'correct', so bear with me thanks. I just figured it originally must of had 2.5" rear drums and been swapped simply because that is what so many on forums etc say. That would be great news if the otherwise was true for this car.
The Charger is in storage and hard for me to access, so does that number 36418 shown in the pic definitely mean there are 3" drums in back currently?
